92 accord ex, not always wanting to start. what could it be?
Old Aug 20, 2007 | 10:51 AM
jdawgshonda's Avatar
Default 92 accord ex, not always wanting to start. what could it be?
I have a 92 accord ex. When the car is hot or its jut hot outside, the D4 light flashes and it WONT start. It turns over but wont start. When its cool outside it will start. Does anyone know what is or could be the problem?
Old Aug 20, 2007 | 06:18 PM
Clean-CB7's Avatar
Default Re: 92 accord ex, not always wanting to start. what could it be? (jdawgshonda)
you need a new main relay. u can either buy a new 1. or taje yours out and re-solder the connections.
Old Aug 23, 2007 | 07:22 PM
cityslicker1606's Avatar
i took mine out i put it in the refrigirator and i put it back in and it worked for about a month
Old Aug 24, 2007 | 08:31 AM
amckee's Avatar
Default Re: 92 accord ex, not always wanting to start. what could it be? (cityslicker1606)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cityslicker1606 &raquo;</TD></TR><TR><TD CLASS="quote">i took mine out i put it in the refrigirator and i put it back in and it worked for about a month</TD></TR></TABLE>Do you actually think the refrigerator had anything to do with it? Tell me this was just a 'tongue in cheek' joke and your really not that stupid.
Old Aug 24, 2007 | 09:06 AM
Honda-Master's Avatar
LOL LMAO,,,LOL, Next time put it in the freezer it might last longer ( 2-3 months )???
Old Aug 24, 2007 | 09:10 AM
it does indeed sounds like the typical main relay issue..Remove it, take it apart and look at the solderings most likely some are cracked ,,you can resolder them or buy a new relay ..
Old Aug 24, 2007 | 11:03 AM
bseriescrxsi's Avatar
Default Re: 92 accord ex, not always wanting to start. what could it be? (amckee)
obviously your not familiar with the problem the HEAT and HUMIDITY affect it the most
Old Aug 24, 2007 | 01:57 PM
gherrera06's Avatar
Default Re: 92 accord ex, not always wanting to start. what could it be? (Clean-CB7)
All about main relay's in this web http://techauto.tripod.com/mainrelaydefine.htm, They explain how to test and fix or replace u main relay, regards
Old Aug 24, 2007 | 03:11 PM
amckee's Avatar
Default Re: 92 accord ex, not always wanting to start. what could it be? (bseriescrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseriescrxsi &raquo;</TD></TR><TR><TD CLASS="quote">obviously your not familiar with the problem the HEAT and HUMIDITY affect it the most</TD></TR></TABLE>So do you think he got it so cold in the refrigerator that it didn't warm up for a whole month? Two idiots in one thread. I'm sure it's not a record.
I'm well aware of relay issues. I have a 92 EX. Cracked solder joints are not repaired in the refrigerator. Removing and replacing the relay, however, could shift things a bit and allow better contact for a while. Humidity has NOTHING to do with it.
Old Aug 26, 2007 | 07:01 PM
one time i took that sumbitch and i threw it down the street and next week i went and picked it up threw that sumbitch back in and it gave my car a huge power boost , thats what i would try if i were u you cant go wrong
tehtyler
Oct 9, 2011 06:28 AM
celbii
Mar 18, 2008 03:59 PM
the GSR spankin' LS
Jul 1, 2005 07:37 PM
Doctor CorteZ
Aug 27, 2004 06:51 AM
MattTwinTurbo
Aug 7, 2002 10:05 PM
