spoon n1 muffler.. 2.0 or 2.5 inlet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcteg »</TD></TR><TR><TD CLASS="quote">I'm 95% sure that its 2.36in. inlet.</TD></TR></TABLE>
I think that's what mine was .... 60mm.
The flange does, however, mate up to the stock B-pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2blueeg »</TD></TR><TR><TD CLASS="quote">bump!</TD></TR></TABLE>
Why are you bumping? The answer was given.
ding ding ding ding ding.
It's a 60mm as eran said.
And mates to stock b-pipes.
http://www.aj-racing.com/catal...age=2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
The flange does, however, mate up to the stock B-pipe.</TD></TR></TABLE>
I believe this is correct on both counts, though it demonstrates one of the "problems" with the Spoon muffler, aside from its relatively high price.
Designing it to bolt up to the stock B-pipe means that there's a significant bottleneck at the flange, which obviously isn't ideal from a performance standpoint. If you're trying to build a high-performance system using this muffler, I'd suggest ultimately having the flange replaced with one that's equal in diameter to the rest of the piping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Designing it to bolt up to the stock B-pipe means that there's a significant bottleneck at the flange, which obviously isn't ideal from a performance standpoint. If you're trying to build a high-performance system using this muffler, I'd suggest ultimately having the flange replaced with one that's equal in diameter to the rest of the piping. </TD></TR></TABLE>
I believe the flange is the same, but the ID is different. It does create bottlenecking, but that is why spoon sells their own B-pipe.
I believe the flange is the same, but the ID is different. It does create bottlenecking, but that is why spoon sells their own B-pipe.</TD></TR></TABLE>
Even the B-pipe features the same bottleneck, since similarly to the muffler section, it is designed to be able to bolt to the stuck muffler.
CIVICon14inBRWs
Dec 6, 2005 04:16 PM
