How to lock rocker arms?
Old Aug 19, 2007 | 07:32 PM
all-mtr-teg's Avatar
Default How to lock rocker arms?
Im trying to check the v2v and p2v clearances, just need to know exactly how to lock rocker arms to check clearances while vtec is engaged. The c-speedracing website says to swap rocker arm pistons to clay motor, is that the same method used to check v2v clearance cause i read (1 2 N V)'s write up and he suggest to stick a BB into the rocker arm, exactly where does the BB go?
Old Aug 19, 2007 | 07:42 PM
1 2 NV's Avatar
Default Re: How to lock rocker arms? (all-mtr-teg)
its either/or. swap vtec pins or throw a BB behind the small vtec pin. both methods work just fine.
Teamdiesel
13
Jul 13, 2009 06:30 AM
matix
Aug 17, 2005 12:33 PM
SPOOLINmatt
May 22, 2005 08:28 PM
Nic
Oct 14, 2004 02:31 PM
Cashflo
Sep 18, 2003 09:29 AM
