Need Help asap......weird IACV problem
Old Aug 19, 2007 | 07:22 PM
mexicanstud's Avatar
Default Need Help asap......weird IACV problem
First of all its a 97 del sol w/ a obd-1 gsr motor all stock....Issue is is that when i unplug the connect from the idle air control valve nothing happens....Of course everyone is gonna say i have a bad IACV, but the thing is i tried 2 other known working IACV on my motor that are the same and the same thing happens....nothing happens when i unplug the connector from the IACV....so im clueless and wondering whats up...maybe some wiring or dunno.....also i was running on a obd-1 gsr ecu and when i held the gas to about 1500rpms the car motor was backfiring or bogging kind of... but when i switched to a obd-2 gsr ecu that problem went away....wondering bout why thats happening and my first issue with the iacv...
ANY SUGGESTIONS would be appreciated
Old Aug 19, 2007 | 08:37 PM
anyone???
Old Aug 20, 2007 | 06:50 PM
someone has to have some input....
Old Aug 20, 2007 | 06:52 PM
forcefedferio's Avatar
Default Re: Need Help asap......weird IACV problem (mexicanstud)
here's a suggestion, if it's all stock why does it need to be obd1? if the problem goes away when you plug in the obd2 computer then, well, use the obd2 computer.
hondamyheart
Nov 7, 2016 11:19 AM
fromthesun_93
Aug 31, 2011 05:07 PM
JONESER
23
Mar 7, 2008 05:09 AM
d0hhh12
Jun 6, 2007 01:41 AM
crackerjacker006
Apr 2, 2007 11:01 PM
