sunroof leak problem
Old Aug 19, 2007 | 05:15 PM
Jdmhonda26's Avatar
Default sunroof leak problem
after every time it rain my seats r dench an the seal around the frame is in tack any help
Old Aug 25, 2007 | 01:35 PM
go250mph's Avatar
Is it the intire seat...or just the outside edges? Mine leaks in around the seat belt tracks somehow.soaks the whole sides of the seats. I'll let you know if I find out something.
Old Aug 28, 2007 | 11:20 AM
DAP91Si's Avatar
Default Re: (go250mph)
I'd check the metal tray that the roof sits in. The outer edges where the rear drain tubes are could be rusted pretty bad.
Old Aug 28, 2007 | 02:15 PM
asianspecialized's Avatar
Default Re: sunroof leak problem (Jdmhonda26)
The sunroofs do not seal around the edges-never have!!!!make sure all 4 of the drain tubes (two along each side)are clear of debris.I have had this complaint many times before.It will also leak in the auto car wash as the drain tubes cannot keep up with the volume of the water.
Old Aug 31, 2007 | 11:24 AM
fizzypopdog's Avatar
ive got the same problem on my 89 16 crx, it leaks on either side in the rear from the boot opener, ive checked the sunroof and it still leaks, ive resealed the rear washer, still leaks, i took all the headliner out, i can see were the water is coming from but i cant figureout how its getting in, it still could be something to do with my sunroof but i cant see how the water would find its way to the channel in the roof were the leak appears from, my only other idea is thats its somehow getting in from the seals that run on the outside of the car above the doors, i cant figure it out , have you sorted yours out yet??? stuart stufizz@hotmail.co.uk
93prelude23
Mar 17, 2014 11:12 AM
FuNkDrSpOt
Dec 28, 2009 08:21 AM
itsmedavid
Jul 18, 2007 04:32 AM
illusion
Dec 11, 2004 08:21 PM
dan89crxsi
Jun 12, 2003 01:06 PM
