cometic fuzion .051 head gasket
has anyone ever had a problem with the fuzion head gasket ( the one with the silver ring) the reason im asking is because the radiator overflow is boiling over after hard pulls and boiling in the top hose. no white smoke,oil is fine,no oil in water,both hoses get hot,and temp on the dataloger is at 208 max. i changed the cap, bled the radiator with the front jacked up and the heater on... all thats left is the headgasket??.................... this is the setup
http://www.boostedmonkey.com/f...=1125
golden eagle hd sleeve 84 mm
finish bore & hone- 4 cylinder
balance/blueprint rotating assembly 10,000 rpm
chamfer oil hole's & micro performance polish crank
golden eagle main studs / arp head studs
factory oil pump
line bore
oem honda rod bearing's
eagle H beam
cp piston's
cometic phuzion .051 head gasket
1,000 cc injector's
golden eagle sandwich plate
AEM fuel rail and fpr
inline pro turbo manifold
GT35R turbo 4 bolt
3 in downpipe with v-flange
tial 38mm wastgate
elderbrock victor-x intake manifold
obx lsd
ACT 6 puck double extreme
12 lb flywheel
greedy boost controler
crower spring's and retainer's
gsr cam's
bMP breather kit ( from the back of the block )
Modified by ant56 at 4:46 PM 8/19/2007
Modified by ant56 at 2:53 PM 8/20/2007
Modified by ant56 at 3:03 PM 8/20/2007
Modified by ant56 at 3:04 PM 8/20/2007
factory oil pump
line bore
eagle H beam
cp piston's
1,000 cc injector's
GT35R turbo 4 bolt
tial 38mm wastgate
obx lsd
12 lb flywheel
gsr cam's
put the front end on the lift again bled the radiator AGAIN for and hour all thats is left is a headgasket.. unless there is a special way to bleed these sleeves.. im guessing that the head gasket only leaks during high cylinder pressure so the water does not have a chanceto enter the chamber. and the air builds up and takes the place of the water..'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 »</TD></TR><TR><TD CLASS="quote">maybe your running to much timing so your head is lifting and now the Hg is compromised</TD></TR></TABLE>
x10
x10
VERY LOW TIMING .. and low boost only 7 lb's till i figure this out.. and the head had 20thousandths taken off.. the ring is gas filled so it expands with lifting
what head gasket is the best ??? i would rather use stock but that will make my compression 10.1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ant56 »</TD></TR><TR><TD CLASS="quote">VERY LOW TIMING .. and low boost only 7 lb's till i figure this out.. and the head had 20thousandths taken off.. the ring is gas filled so it expands with lifting
what head gasket is the best ??? i would rather use stock but that will make my compression 10.1</TD></TR></TABLE>
id say get rid of the cometic pHuZSi0N gasket and run a oem. 10.1 isnt that bad, just get a good tuner.
The head is supposed to have a certain surface finish for a metal gasket, not just plained.
Leaking aftermarket metal gaskets due to people not having the head surface properly finished is a pretty common occurance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWDstylez »</TD></TR><TR><TD CLASS="quote">
Leaking aftermarket metal gaskets due to people not having the head surface properly finished is a pretty common occurance.</TD></TR></TABLE>
yea any good machine shop will leave your head with a almost mirror like finish when they resurface heads. if it doesnt look like a mirror, you got screwed.
10.1 isnt thaT BAD just less room to play with.. i duno maybe.. i do have meth injection my goal is 600 hp and we do our own tuning using crome pro with rtp
Modified by ant56 at 5:14 PM 8/20/2007
i agree... oem is the best my b20vtec turbo has a golden eagle head gasket . its pushing 8lbs at 10.8 compresion and it's been good for a year.. i just want lower compresion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">maybe you can look into golden eagle headgaskets for this build if there available. Like you stated, the tune is fine, your not pushing is too hard </TD></TR></TABLE>
golden eagle are just oem gaskets bored out.
If it makes you feel any better
100% stock bottom end
B18C, LS/VTEC:
1. crx=si 605hp, 364tq stock B18C1 TO4R at 26psi Crome-pro with traktek 110
B16:
1. Randys 630whp and 390tq on 118. (10.97@131)
B18C, LS/VTEC:
B16:
