need help !
Old Aug 19, 2007 | 03:07 PM
19992civichatch's Avatar
Default need help !
i got a b18b motor in my crx we jsu tgot it started and when we pull the butterfly to give it more gas it falls on its face. what could this be
Old Aug 19, 2007 | 03:40 PM
Crx dude's Avatar
Default Re: need help ! (19992civichatch)
Have you checked fuel pressure?
Old Aug 19, 2007 | 03:41 PM
Hamstr323's Avatar
timing?
Old Aug 19, 2007 | 05:32 PM
garageEF's Avatar
Default Re: need help ! (Hamstr323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">timing?</TD></TR></TABLE>
x2
Old Aug 19, 2007 | 05:37 PM
denraweb's Avatar
Default Re: need help ! (garageEF)
I just had this same problem when I swapped my b16 crx...guess what it was...no gas...look at it like this, when you open the butterfly, more air goes in, and the more the air goes in, the more gas has to be in...the car idled perfectly fine, so I didn't think of that at first...it would even start up after being turned off...running on fumes I guess. But try putting gas...2 gallons should be more than enough, and also check the pressure.
Old Aug 19, 2007 | 07:26 PM
has gas in it at its at like 50psi
could it be a dirt fuel filter? or injectors im throwing a code 16
Old Aug 19, 2007 | 09:32 PM
garageEF's Avatar
Default Re: (19992civichatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch &raquo;</TD></TR><TR><TD CLASS="quote"> or injectors im throwing a code 16</TD></TR></TABLE>
well there you go....fix the code, fix the problem
Old Aug 20, 2007 | 03:15 AM
etant333's Avatar
only throwing injector code because we disconnected the injectors while it was running but im also throwing a code 43 fuel system code so alot of people are telling me to put on a stock regulator to start with ause it could go bad then check to make sure all injetors are spraying the same then fuel pump
SOL Food
25
Oct 29, 2008 05:49 PM
AGENT 99
36
Apr 20, 2006 12:06 AM
rushin
Nov 12, 2004 10:55 PM
baonest1
Aug 18, 2003 11:22 AM
