h22 swap not getting fuel. 92 accord
I have been swapping an h22 with h23 5 speed tranny into his previously automatic 92 CB7.
The motor is in not problem. WE are not exactly sure what kind of injectors came with it, so currently we have f22 injectors in it. WE did not cut the wiring harness, just added the VTEC harness stuff. It has a chipped p06 with vtec added in it. Fuel is going through the rail. We have swapped injectors, injector resistor boxes, fuel pressure regulators. Motor is getting spark. Oh, swapped distributor, plug wires, coils too. When the spark plugs are pulled there is not any fuel on them after cranking the engine MANY times. The timing is believed to be correct. Everything switched came from either a previously running motor, or currently running motor. The 5speed wiring is exactly the same on his swap guide. IF anybody has any ideas please chime in. Also there are no CELs when cranking or anything.
Modified by The G-Man at 9:00 AM 8/19/2007
