quick question........
Old Aug 18, 2007 | 08:43 PM
killafred187's Avatar
Default quick question........
do i have to change the whole hub if the the little lip around the axle nut is messed up?? [IMG][/IMG]
Modified by killafred187 at 1:33 PM 8/19/2007
Old Aug 18, 2007 | 09:03 PM
bump!!! plz help
Old Aug 18, 2007 | 09:09 PM
hybrid1990crx's Avatar
Default Re: quick question........ (killafred187)
what lip? on the axle bolt itself? technically axle bolts are suppose to be a one time use thing.
Old Aug 18, 2007 | 09:50 PM
Default Re: quick question........ (hybrid1990crx)
no the lip around the bolt
Old Aug 18, 2007 | 10:01 PM
bump!!!
Old Aug 19, 2007 | 12:04 AM
Suck my DX's Avatar
Default Re: (killafred187)
what the hell is an axle bolt?
to the OP....its fine...you dont really need to change the nut unless its thrashed...yours looks fine to me i wouldnt sweat it.
Old Aug 19, 2007 | 12:55 AM
RCautoworks's Avatar
As long as it threads on, and you can punch the tab back in so it don't spin off, you will be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx &raquo;</TD></TR><TR><TD CLASS="quote">what lip? on the axle bolt itself? technically axle bolts are suppose to be a one time use thing.</TD></TR></TABLE>
Yeah technically , when putting in a new axle we always use new axle nuts, because they always come with new ones.
Old Aug 19, 2007 | 06:55 AM
91ed9's Avatar
Default Re: quick question........ (RCautoworks)
I think the OP is talking about the lip that your suppost to hit down into the little notch on the axle end
if there is no more lip to pinch in there then get a new axle nut!
Old Aug 19, 2007 | 07:03 AM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killafred187 &raquo;</TD></TR><TR><TD CLASS="quote">do i have to change the whole thing if the the little lip around the axle bolt is messed up?? [IMG][/IMG] </TD></TR></TABLE>
Well only VWs have axle "Bolts" and to me it looks like you circled the lip to the actual Hub??? that has nothing to do with your axle "Nut".
and to be honest your question is WAY to vague to properly answer, change what "whole thing", the Axle? the Hub? the Axle Nut? man be more specific, we can't read your mind (we can barely read your post)
Old Aug 19, 2007 | 11:15 AM
i mean the hub.............. my bad
Old Aug 19, 2007 | 12:32 PM
bump!!!
Old Aug 19, 2007 | 12:36 PM
You're fine.
Old Aug 19, 2007 | 12:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">You're fine. </TD></TR></TABLE>
Correct, your hub is not affected by that lip. The lip is mainly for your rotor wheel to sit hubcentrically on so it stays in place and centered. At most if the lip gets to bent you'll have to grind off the excess when replacing rotors cause the rotors won't clear the lip if it's to bent. No big deal either way
Old Aug 19, 2007 | 06:09 PM
Default Re: quick question........ (VtecSyndrome)
bolt. nut. i screw that up all the time. i know im dumb.
Old Aug 20, 2007 | 01:24 PM
same here thanks guys!!!!
wasanissanFL
Honda Fit
Mar 8, 2012 06:51 PM
lapulapu
Jul 15, 2008 02:08 PM
EFM_ookie
16
Aug 14, 2005 09:27 PM
viciousvisionslarry
Sep 30, 2004 07:47 AM
hybrid515
15
Jun 9, 2004 07:18 PM
