are all d-series axles the same?
Old Aug 18, 2007 | 07:35 PM
nicko360's Avatar
* B A N N E D *
Default are all d-series axles the same?
will axles from an ek fit an ef?
Old Aug 18, 2007 | 08:02 PM
MatterMatt's Avatar
Default Re: are all d-series axles the same? (nicko360)
I don't think so. Check the part #'s.
Old Aug 18, 2007 | 08:14 PM
hmtcrxsir's Avatar
Default Re: are all d-series axles the same? (MatterMatt)
yes its all interchangable.
Old Aug 18, 2007 | 08:18 PM
highroller54's Avatar
Default Re: are all d-series axles the same? (hmtcrxsir)
dont hf's have really small splines?
Old Aug 20, 2007 | 03:27 PM
MatterMatt's Avatar
No, the 96+ and 88-91 civics have different part numbers for the axles. Not the same axles, not interchangable.
Old Aug 20, 2007 | 04:53 PM
Super Chicken's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatterMatt &raquo;</TD></TR><TR><TD CLASS="quote">No, the 96+ and 88-91 civics have different part numbers for the axles. Not the same axles, not interchangable. </TD></TR></TABLE>
You are correct again!!!! j/k
I have a set of 88-91 axles and I wanted to put them in a car I was working on (94 civic dx) and they are too short! So no, they won't fit
Old Aug 20, 2007 | 04:54 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: are all d-series axles the same? (Super Chicken)
All d-series HYRDO axles are the same.
so basically 92-00 axles as far as civics go.
1993 da d-series axles will not work.
Modified by ek forever guy at 9:41 PM 8/20/2007
Old Aug 20, 2007 | 06:30 PM
MADMAX_zero's Avatar
Default Re: are all d-series axles the same? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">All d-series HYRDO axles are the same.
so basicall 92-00 axles as far as civics go.
1993 da d-series axles will not work.</TD></TR></TABLE>
Correct. Also same for manual and automatic. Same axles.
Old Aug 20, 2007 | 06:43 PM
forcefedferio's Avatar
Default Re: are all d-series axles the same? (highroller54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 &raquo;</TD></TR><TR><TD CLASS="quote">dont hf's have really small splines?</TD></TR></TABLE>
yes the hf's have smaller splines which is why you need to convert your knuckles to si/lx/dx etc. when doing a b series swap in a 4th gen that is an HF
blake22
Feb 18, 2007 06:59 AM
DFW
Sep 8, 2006 12:04 PM
TurboSI24
Oct 14, 2005 12:42 PM
Sleeping4drLS
Mar 6, 2003 02:46 PM
