f23 crankshaft w/ h22a4 block
Old Aug 18, 2007 | 07:22 PM
ge_itr's Avatar
Default f23 crankshaft w/ h22a4 block
this was partially in my other thread but the title wasn't that relative to this subject. for those of you that have done or know about using a f23 crankshaft in a h22a4 block (going all motor), please post any info you know. i've have just thought about doing this and i need all the info that i can get. how well does it work together etc.? thanks.
Old Aug 19, 2007 | 07:10 AM
alterdcreations's Avatar
Default Re: f23 crankshaft w/ h22a4 block (ge_itr)
use s2000 pistons with the f23 rods and crank
Old Aug 21, 2007 | 07:20 AM
ge_itr's Avatar
will my stock parts like alternator, power steering, belt tensioner,... etc on the h22a1 block bolt on to the new h22a4 block correctly? any modds?
if i get the f23 crank and h22a4 block, can i still use my wiseco pistons that i bought for the h23 crank and h22a1 block?
Old Aug 21, 2007 | 07:41 AM
Speedra500's Avatar
Default Re: (ge_itr)
take a little initiative, you can figure out if your pistons will work by taking your deck height and subtracting the stroke, rod length, compression height and that should tell you how far in out of the block your pistons will be, and from there you can determined whether or not your pistons will work or what you need to do to make them work
whytTypeR
Feb 8, 2005 06:42 PM
topsekret
Aug 5, 2003 08:33 PM
myNAteq
Nov 8, 2001 10:37 AM
