A pipe heat shield
Old Aug 18, 2007 | 06:37 PM
SpeedoKing's Avatar
Default A pipe heat shield
jus to double check this heat shield i think it is called the A pipe heat shield is loose on my car and i dont have the cash to replace it but can i jus take it off and not worry about doing any harm to my car?
http://www.eliteone.com/civic/cat-oem.jpg
thanks for any advice
Old Aug 18, 2007 | 06:40 PM
Padawan's Avatar
Darth ModerVader
Default Re: A pipe heat shield (SpeedoKing)
That's the cat heat shield. It should normally be attached with bolts, so rather than removing it, why not just tighten them?
Old Aug 18, 2007 | 06:42 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: A pipe heat shield (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">That's the cat heat shield. It should normally be attached with bolts, so rather than removing it, why not just tighten them?</TD></TR></TABLE>
I agree, and even if the bolts or the seat is stripped tapping or buying new bolts is a much easier option IMO.
a 5th gen I got to work on had a similar problem. One of the bolts had totally rusted out. So I took it out, got new ones and replaced them all.
Old Aug 18, 2007 | 07:58 PM
SpeedoKing's Avatar
Default Re: A pipe heat shield (ek forever guy)
ok thanks guys....i could swear that on a 99 ex there was a heat shield b4 the cat but i could be wrong ill find out tomorrow when i put the car up. it rattles and is driving me crazy it makes my car sound like a beater.
Acidcrakker
Oct 12, 2007 06:19 AM
94B18B1Teg
Mar 15, 2004 11:05 AM
B18CYAAA
Jul 24, 2003 08:28 AM
f1uxx
Apr 23, 2003 12:40 PM
jabenne
Apr 24, 2002 03:57 PM
