1995 accord 155,000 miles
Old Aug 18, 2007 | 05:09 PM
heydave23's Avatar
Default 1995 accord 155,000 miles
The car sometimes will not turn over even when the clutch is pushed all the way to the floor. No click or anything. After 2-5 times of repeated times the engine will start. Any ideas?
Old Aug 18, 2007 | 05:44 PM
ddg2sailor's Avatar
Ignition switch or safety neutral switch.
Put it in neutral , hold the key in the start position then go up and down on the clutch at the same time.... if the car turns over intermittently then it might be the safety neutral switch otherwise id be thinking about a new ignition switch.
No click at all? I would have expected to at least hear the solenoid on the starter...
I have a 93 myself.. but i hope I have been of some help.
Old Aug 18, 2007 | 06:42 PM
DC2MK's Avatar
Default Re: (ddg2sailor)
I would def. say your starter is going bad. When it doesnt start, try tapping the starter with a small hammer. It should start right up. I have had the same problem in the past.
Old Aug 18, 2007 | 07:45 PM
hondaccord's Avatar
Default Re: (DC2MK)
i have seen a loses battery start that.
Blaze45
Nov 29, 2017 12:07 PM
siblues
Oct 2, 2014 11:25 PM
Goldest
Dec 15, 2010 03:07 AM
carve
Sep 12, 2009 09:35 PM
stRodda
Mar 5, 2004 03:56 PM
