trunk light comes on help!!!
Old Aug 18, 2007 | 02:51 PM
socalrex88's Avatar
Default trunk light comes on help!!!
so juss the other day i replaced the ground wire the one onthe engine head cover. iono what that has to do with the trunk light but trnk light came after doin that. and that was the only thing idid that day. yes imade sure trnk was slammed tight.is it my trnk sensor? plzz help its really annoying when driving.....
Old Aug 18, 2007 | 03:44 PM
CRX Toad's Avatar
Default Re: trunk light comes on help!!! (socalrex88)
If it is a CRX as your SN seems to appear there is a switch on the light itself since there is no sensor telling it to turn off.
What car are you speaking of?
Old Aug 18, 2007 | 04:39 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: trunk light comes on help!!! (CRX Toad)
see if you have a alarm in the car or did....i tend to tap the hood pin and trunk together which in turn would cause the trunk light to be on when the hood is open. see if there is a hood pin and see if it came unplugged
Old Aug 19, 2007 | 12:40 AM
socalrex88's Avatar
i drive the crx hf......a switch to turn it off? where can i find that?? and what is a "sn"???
Old Aug 19, 2007 | 12:44 AM
socalrex88's Avatar
yeah the car does or use to now had an alarm....i dont kno what kind it is but i checked the alarm speaker thingymajig it has a on and disable switch......the alarm is the shape of a square type box that only works if you put battery in them like those little rectangle ones....but ill check thanx for responding you guys...
professorman
Mar 31, 2014 02:34 PM
bignedz
Honda Civic (2001 - 2005)
Aug 12, 2012 10:24 AM
ninjarich2
Audio / Security / Video
14
Nov 17, 2007 10:27 PM
kelpike
Aug 4, 2007 05:33 PM
88EF96EK
May 24, 2003 04:28 AM
