I've had problems with the balancers and various other parts...
Old Aug 18, 2007 | 10:45 AM
plikit's Avatar
Default Vacuum Leak = burned oil
so i originally thought this problem was timing related... BUT its not.
SYMPTOMS:
Large amounts of oil being burned.
High / Surging Idle.
Exhaust gurgling.
Oil fouled plugs / plug chambers filled with oil.
Lets just say i was extremely scared that my rings were bad (especially since I just had this bitch rebuilt 3 years ago.)
I discovered a rather large vacuum leak coming from most likely a gasket.
now how does this effect oil consumption i wondered... well past experience showed me that when i replaced #16 in the picture below with one of those little breather filters i got the similar symptoms. (I saw several cars with this done and I assumed it was ok to do).
well now that about 40-60% of the air getting sucked into my engine is not passing this hose (#16) and therefore not creating a suction on it my car is drinking oil and the plugs chambers are getting filled with oil... theres not enough pressure being relieved in the head. i wish i had a picture because you can even see oil seeping from one of the valvecover studs.
Modified by plikit at 9:45 PM 8/28/2007
Modified by plikit at 9:48 PM 8/28/2007
Old Aug 18, 2007 | 01:01 PM
plikit's Avatar
Default Re: I've had problems with the balancers and various other parts... (plikit)
bump
Old Aug 18, 2007 | 02:11 PM
117's Avatar
117
You need to pull the timing belt cover off and inspect everything at a minimum.
Old Aug 18, 2007 | 05:35 PM
plikit's Avatar
Default Re: (117)
i suspect the auto-tensioner may play a role in this..
but ill just update after i inspect the timing belt
Old Aug 22, 2007 | 09:11 PM
plikit's Avatar
Default Re: (plikit)
ok, update.
turns out i have a rather large vacuum leak somewhere. WHICH I should have known from the symptoms. I once replaced a couple of vacuum hoses and got them reversed and my car started burping...
I bet my intake manifold has possibly come somewhat loose or taken some damage. It really sounds like 40-60% of the air going into my car IS NOT going thru the filter... I know, NOT GOOD! this should solve the high idle and weird exhaust sound. maybe itll help with the car vibration.
for making progress
for having a broken car
Old Aug 28, 2007 | 08:46 PM
plikit's Avatar
bump for some new help.
see first post for update
Old Aug 28, 2007 | 10:26 PM
plikit's Avatar
night bump
whiteformula98
Aug 17, 2008 11:49 AM
crxaddikt
Aug 20, 2003 11:24 AM
wm5holla
May 19, 2003 07:30 PM
redteg1
Aug 27, 2002 10:39 AM
sushibug
Jun 10, 2002 11:07 AM
