single v boosted rad hose crx?
im using a half rad from an eg in my crx i got traction bars tho
wut hoses should i use/buy/get 4 my swap? like ima use saamco so i dont want 2 buy the wrong ones...
I used that set up. I went to Autozone and just got the correct diameter in some random hose. Then I just went home and cut it to custom fabricate it. The Y8 is pretty easy to connect because of its diagonal lead to the upper hose. The lower hose I used my A6 hose.
GL, and I am pretty sure you can just fabircate the a6 UH to fit the y8 seeing that the distance is much shorter.
GL
GL
i have a half cut in my 4 door. now is the radiator made for 88-91 or is it the 92-00 radiator. if its the 92-00 radiator dont do it. i had a hell of a time gettin mine in just right.
Sprockets
Sep 28, 2016 07:52 AM
