EK HATCH automatic transmition is shifting only at high rpm's
Old Aug 17, 2007 | 09:22 PM
dailyekhatch's Avatar
Default EK HATCH automatic transmition is shifting only at high rpm's
it just started to shift by itself at high rpm's. first gear wont change until 25mph and 2nd gear wont change around 55mph. does anyone have any clue to what this might be?
Old Aug 17, 2007 | 09:38 PM
Default Re: EK HATCH automatic transmition is shifting only at high rpm's (dailyekhatch)
also its not throwing any cel's
Old Aug 17, 2007 | 10:59 PM
gourley's Avatar
Change your oil
Old Aug 17, 2007 | 11:36 PM
fdavie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dailyekhatch &raquo;</TD></TR><TR><TD CLASS="quote">it just started to shift by itself at high rpm's. first gear wont change until 25mph and 2nd gear wont change around 55mph. does anyone have any clue to what this might be?</TD></TR></TABLE>
Sounds to me like the transmission isn't shifting properly - it's only shifting to protect the engine from overreving. I'd take it to a transmission shop/dealer; autos are way complex...
Old Aug 17, 2007 | 11:45 PM
cartune network's Avatar
Default Re: EK HATCH automatic transmition is shifting only at high rpm's (fdavie)
there not that complex. but i doubt ur gonna be able to figure it out on ur own especially if u have never screwed around with an auto tranny. ur best bet is to just take it to a tranny shop. DONT change the oil. if u have never changed the tranny fluid in the tranny and u have high mileage ur going to make the problem worse. there is certain clearances in an auto tranny that must stay the same and when the fluid gets old it causes the clutch paks to stay in position cause the old fluid gets thicker over time and the new fluid is thin which would cause the clearances to get larger which u dont want in an auto tranny.
Old Aug 19, 2007 | 05:10 PM
Default Re: EK HATCH automatic transmition is shifting only at high rpm's (cartune network)
i've been real busy and i havent had time to look at the thread. but i'm probably going to take it to a transmition shop. i have to put the car into netural then i can shift it into drive or reverse etc... but if its in park it gets stuck
USDM-EK4*
Jun 5, 2007 09:33 PM
bluesaint
Aug 9, 2006 06:07 AM
Captain Flaps
Jun 4, 2006 02:02 PM
Dark_Helmet
May 31, 2005 11:29 PM
frostcivic
Jun 18, 2004 09:06 PM
