FS: H2B swap JDM H22a type S motor, B16 tranny
Any pictures? Does the motor include the intake manifold, throttle body, exhaust manifold, fuel rail & injectors, starter, engine harness, sensors (nothing broken)?
Modified by TrackSpeedRacing at 8:36 AM 8/18/2007
from my PM i sent you...
DeuceD (8:16 PM 8/17/2007): there has been some slight changes from the original listing.
no Hasport mounts, axles, intermdiate shaft, alternator and injectors. i didnt recieve those parts when i got the H2B swap from the deal/trade.
pics coming up right now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrackSpeedRacing »</TD></TR><TR><TD CLASS="quote">Didnt the JDM TYPE-S motors have a Red Valve Cover as opposed to the black one? The motor should be either a 97-98. Let me know.</TD></TR></TABLE>
how can we verify its a type s motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEV3-O »</TD></TR><TR><TD CLASS="quote">
how can we verify its a type s motor?</TD></TR></TABLE>
ok, from what i was told, the engraved serial #s on the block corresponds w/ the type of motor it is based on the year of the production date. I was told that any # starting w/ a 3xxxxxxx on it was a 97-98 Type S version motor on it. I am trying to verify this information. But i also have a reciept from the place i bought this motor from as well if you need proof of purchase.
On the head, it has the stamping 96 w/ the arrow pointing to the 9 which tells me that this motor was produced in late 96 which also makes this a 97 H22 motor. I do not believe that the block and head have ever been separated but im not that far of an expert either.
Modified by DeuceD at 12:50 AM 8/21/2007
type s motors had red valve covers and
THe s-spec motor will have a red top and the oil filter will be straight out on the back of the block. A type S red top but oil filter will be angled up. They are both going to have H22a as a engine code though. The type s and SH are the only ones with the oil fitler angled. So if it isn't angeled and red top then most likely it will be a S-spec motor.
Hope that helped you out. That is the easiest way to tell the difference just by looking at it.
DeuceD
Aug 23, 2007 12:01 PM
4LugR
Northern California (Sales)
19
Aug 17, 2007 07:22 PM
