SAE vs. METRIC thread pitch ?
Old Aug 17, 2007 | 06:48 PM
Propulsion's Avatar
Default SAE vs. METRIC thread pitch ?
If I tap a 4mm hole with a metric tap, will a SAE bolt of similar size go in there or will it cross thread?
Old Aug 18, 2007 | 06:46 AM
Flashmn's Avatar
Default Re: SAE vs. METRIC thread pitch ? (Propulsion)
use some common sense, it will cross thread or just be loose.
Old Aug 18, 2007 | 07:54 AM
Propulsion's Avatar
Default Re: SAE vs. METRIC thread pitch ? (Flashmn)
how is that common sense? I know the holes have difference diameters but my question was whether the 2 systems use difference thread pitches.
If the pitch is the same, and the hole diameter is slightly off, I can just use some locktite when I thread the bolt in there.
Old Aug 18, 2007 | 08:33 AM
King V's Avatar
Thats like feeding a Mogwai after midnight. SAE and Metric are real close, BUT not the exact same. It will cross thread, because of the pitch difference.
Old Aug 18, 2007 | 10:43 AM
Propulsion's Avatar
Default Re: SAE vs. METRIC thread pitch ? (200kCivicSI)
thank you, that's the simple answer I was looking for -- "the pitch is different"
Tyler Dirden
Apr 27, 2013 12:46 PM
Luckywhiteboi
Mar 6, 2009 03:58 AM
B18EG6
Jan 12, 2005 08:15 AM
DB8_TEG
Oct 24, 2003 04:03 PM
