code 0?!!!!
Old Aug 17, 2007 | 04:42 PM
93sihatchy's Avatar
Default code 0?!!!!
ok well how do u get a code 0 on a obd1? the light just stays on when u bump it?i think my ecu went bad im getting no spark or fuel and the car just died and will not start . try eerything and nothing working when i try to pull the codes(have done it before manytimes) the chek eng light just stays on...is that a code 0 ? lol
Old Aug 17, 2007 | 05:21 PM
lsvtec-crx's Avatar
Default Re: code 0?!!!! (93sihatchy)
swap ecu's with a friend.see if that works.
Old Aug 17, 2007 | 05:23 PM
93sihatchy's Avatar
Default Re: code 0?!!!! (lsvtec-crx)
try to get ahold of 1 lol but how would code0 show up?
Old Aug 17, 2007 | 05:36 PM
lsvtec-crx's Avatar
it wont show up,the car should start if the ecu is the problem
Old Aug 17, 2007 | 06:54 PM
93sihatchy's Avatar
car dont start the start turns it over/
Old Aug 17, 2007 | 07:00 PM
mastershultz's Avatar
does the oil can light?
Old Aug 17, 2007 | 07:52 PM
93sihatchy's Avatar
Default Re: code 0?!!!! (mastershultz)
yea.....y?
Old Aug 17, 2007 | 08:02 PM
93sihatchy's Avatar
tttt
Old Aug 18, 2007 | 11:50 AM
93sihatchy's Avatar
ttt
Old Aug 18, 2007 | 12:14 PM
93sihatchy's Avatar
bump
Old Aug 18, 2007 | 12:41 PM
pdiggitydogg's Avatar
a non flashing ecu means its fucked (assuming you jumped it correctly)
You need to find another ecu...borrow one, dont ask how
Old Aug 18, 2007 | 12:43 PM
93sihatchy's Avatar
Default Re: (pdiggitydogg)
yea the oil can and check eng light just stay on and i try so many time to pull the codes and friends have tried..
Old Aug 18, 2007 | 01:04 PM
93sihatchy's Avatar
Default Re: (93sihatchy)
ttttt
Old Aug 18, 2007 | 05:18 PM
93sihatchy's Avatar
bump
Old Aug 19, 2007 | 05:28 AM
Theres no point in bumping the thread until you can source another ecu of the same type. Its obviously a bad one...
As for the oil light - its going to stay on until the car runs. Just forget about it.
Old Aug 19, 2007 | 07:57 AM
93sihatchy's Avatar
yea got the ecu it not the ecu it seems lke a the main relay..
lvlistchif
Oct 4, 2009 11:40 AM
ANONYMOUSdeecee
Mar 7, 2007 07:47 PM
Bseriesy0
Nov 7, 2003 11:43 AM
BigMig
May 10, 2003 06:01 PM
RedRacerCivic
Dec 6, 2001 11:45 AM
