Picture of oil pressure switch
Old Aug 17, 2007 | 03:34 PM
lude98SH's Avatar
Default Picture of oil pressure switch
Does anyone have a picture of an oil pressure switch (installed) from a base model or 4th gen vtec lude ?
Old Aug 17, 2007 | 04:17 PM
snobordboy's Avatar
Moderator
Default Re: Picture of oil pressure switch (lude98SH)
are you looking for the vtec oil pressure switch or just an engine one?
Old Aug 17, 2007 | 04:23 PM
typeSwarrior's Avatar
I'm in the middle of a rebuild for my H22 and have been logging a bunch of photos of work-in-progress. I only have a couple at my place, the rest are on my dad's camera memory card. This was actually the cause of my severe oil leak (as you can see in the photo). This is the best photo I could find on my desktop. Hope this helps.
Old Aug 18, 2007 | 08:43 AM
lude98SH's Avatar
Default Re: Picture of oil pressure switch (typeSwarrior)
i know where it is but i need to see how it connects to the harness exactly. I think it may be alittle different that the SH but im not sure.
Old Aug 18, 2007 | 04:24 PM
Hawkze_2.3's Avatar
It's that single black wire with a ring terminal on the end of it if I remember right...hard to miss on the harness.
Old Aug 18, 2007 | 07:08 PM
lude98SH's Avatar
Default Re: Picture of oil pressure switch (Hawkze_2.3)
Im using the SH harness which looks like it different, i figure i could just put a ring connector on the wire but want to see a picture of how it actually connects.
Heres how it is on the SH.
http://www.hondaautomotivepart...AINER
Old Aug 18, 2007 | 07:39 PM
vinuneuro's Avatar
Did you try looking at the Helms? The picture is relatively detailed on page 8-10.
Old Aug 18, 2007 | 07:44 PM
lude98SH's Avatar
Default Re: Picture of oil pressure switch (vinuneuro)
ok i see the picture your talking about. So its always a 1 wire sensor ?
Old Aug 18, 2007 | 07:55 PM
osb's Avatar
osb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">This was actually the cause of my severe oil leak (as you can see in the photo).</TD></TR></TABLE>
mine leaks also, but not severly and i replaced it but it still leaks...did yours stop the leak after you replaced it?
Old Aug 18, 2007 | 08:00 PM
saikou's Avatar
Default Re: Picture of oil pressure switch (osb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by osb &raquo;</TD></TR><TR><TD CLASS="quote">
Did you wrap the threads with teflon tape?
Old Aug 18, 2007 | 08:14 PM
lude98SH's Avatar
Default Re: Picture of oil pressure switch (saikou)
so i guess all i have to do is find a ring connector that will fit it and cut the connector off the stock harness ? Anyone that maybe has done this or has more info please comment.
Old Aug 18, 2007 | 09:53 PM
vinuneuro's Avatar
It looks like it should be a pretty simple affair replacing the connector at the end of the wire.
Old Aug 19, 2007 | 05:39 AM
lude98SH's Avatar
hmm so any ring connector that fits snuggly should work ..right ?
Old Aug 19, 2007 | 04:33 PM
lude98SH's Avatar
i have the switch out however the screw inside it just keeps spinning. I bought a new sensor however the screw doesnt come with it.
Old Aug 19, 2007 | 04:42 PM
lude98SH's Avatar
also it says use sealant.....what type of sealant do they recomend ??
Old Aug 19, 2007 | 05:29 PM
vinuneuro's Avatar
Where does it say that?
Old Aug 19, 2007 | 05:31 PM
lude98SH's Avatar
i have the factory honda manual it says it on page 8-3 of that. It says use proper liquid sealant.
Old Aug 19, 2007 | 05:34 PM
vinuneuro's Avatar
Ah.. I was looking at 8.10-8.11. My guess would be something like this. http://www.neweraadhesive.com/products_2.htm#ls
Old Aug 19, 2007 | 05:38 PM
lude98SH's Avatar
i have permatex **** and also hondabond ? Would that work ?
Old Aug 19, 2007 | 05:41 PM
vinuneuro's Avatar
I'd lean towards Hondabond since it performs duty under similar conditions around the oil pan. Use it sparingly on the threads though.
Old Aug 19, 2007 | 07:29 PM
lude98SH's Avatar
thanks man
jamesonc
May 4, 2010 03:21 PM
shepn8tr
Apr 13, 2008 06:44 AM
FlyingDaggers
Nov 9, 2007 11:48 AM
mtber
Aug 10, 2003 03:21 AM
