Upgrading brake's. Si --> VTEC (or better)
Old Aug 17, 2007 | 12:17 PM
TylerC161's Avatar
Default Upgrading brake's. Si --> VTEC (or better)
I searched, and theres some minor information as far as upgrading the brakes goes. And most of the information including pics and such is from 2002 and all of the images are expired. I've currently got a 1996 Si with stock brakes, calipers, rotors, ect and I would like to upgrade to the larger VTEC rotors (Brembo) but I need to know what else I will need.
Im automatically assuming with the rotors, im going to need the calipers. Im going to work on finding prelude VTEC oem ones (or perhaps brembo also), but the Legend and NSX sparks interest. What I wanted to also know more information on is if I get legend or NSX calipers, will I need respective rotors, or will prelude vtec ones work?
I also dont want to have to change my bolt pattern is any other parts require it (like NSX and legend rotors)
Who can shine a little more light in my direction?
Old Aug 17, 2007 | 12:24 PM
nonvteclude's Avatar
Default Re: Upgrading brake's. Si --> VTEC (TylerC161)
everything you need to know on brake swaps. https://honda-tech.com/zerothread?id=1588150 FAQ's
Old Aug 17, 2007 | 12:47 PM
TylerC161's Avatar
Default Re: Upgrading brake's. Si --> VTEC (nonvteclude)
So VTEC Rotors and calipers it is then
Thanks
Old Aug 17, 2007 | 04:23 PM
snobordboy's Avatar
Moderator
I coulda sworn you only needed vtec rotors and the mounting brackets for the calipers?
Old Aug 17, 2007 | 10:02 PM
MLBZ521's Avatar
The link nonvteclude posted and:
https://honda-tech.com/zerothread?id=579618
For the Legend Caliper Swap.
You need to do a lot more research before you buy anything.
First, VTEC and Si Calipers are the Same. Same size Piston at least. Only thing different is the Bracket, that will be all you need to upgrade to VTEC Size, 11.1", Rotors.
You wouldn't be using NSX or Legend Rotors, that wouldn't work.
You could use the Calipers and Brackets from the NSX or Legend, yes.
The Legend Pistons are 2mm larger than the NSX Pistons, but the NSX Calipers are much lighter than the Legends.
I'm not sure how thick the NSX Rotors are, but I know the Legend Rotors are 5mm thicker than the Prelude Rotors, so you'll have to fix that using Legend Calipers with Stock VTEC Prelude Rotors.
Old Aug 17, 2007 | 11:20 PM
TylerC161's Avatar
Default Re: Upgrading brake's. Si --> VTEC (MLBZ521)
I think im going to stick with the bracket and vtec rotors, thanks guys!
Old Aug 18, 2007 | 12:02 AM
veetak's Avatar
The piston might be the same size, but if you put the 2 calipers next to each other you can visually see the difference. If I can find my old ones I'll take a pic tomorrow
Old Aug 18, 2007 | 07:27 AM
MLBZ521's Avatar
Default Re: (veetak)
Yes, as I said, the pistons are the same size, the rest of the Caliper doesn't really matter..
Old Aug 18, 2007 | 09:23 AM
halfNhalf-83's Avatar
that and there is nothing special about the prelude VTEC piston anyways. its the same pistons used on
97-01 crvs (all models)
92-01 preludes (all models)
90-93 accords (all models)
94-97 accords (lx,ex,v6 models)
95-98 odysseys (all models)
06-07 accord 4dr
nothing special lol.
Old Aug 18, 2007 | 02:15 PM
MLBZ521's Avatar
Default Re: (halfNhalf-83)
Yea... Don't think anyone said it was..
Just the Brackets are different to allow slightly larger rotors.
Old Aug 18, 2007 | 02:28 PM
Apex1972's Avatar
Default Re: (MLBZ521)
so you are saying that the caliper is the same???if thats the case, I should just get the new rotors??? I do not think the caliper is same though because the Si and VTEC have different front pads. that tells me that the caliper is NOT the same.
Old Aug 18, 2007 | 06:43 PM
MLBZ521's Avatar
Default Re: (Apex1972)
Read the entire thread....
The Calipers are not the same, the Piston is different. The Caliper doesn't matter. The Rotors are different. Si is 10.2" and the VTEC is 11.1", so yes, there will be different pads.
Old Aug 18, 2007 | 10:28 PM
veetak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">
The Calipers are not the same, the Piston is</TD></TR></TABLE>
fixed
Old Aug 19, 2007 | 02:45 PM
MLBZ521's Avatar
I see nothing different between what I have posted and what you posted...
What did you fix again???
Old Aug 19, 2007 | 03:09 PM
MLBZ521's Avatar
Ah, a friend told me what I said wrong, just wasn't able to tell what you meant... Heh
Fixed:
The Caliper is physically different, but the Pistons are the same Size.
DOHCMonster410
May 26, 2009 09:06 PM
93sivtec
Jan 12, 2007 09:20 AM
superturboprelude
Jan 12, 2004 05:42 AM
ItzTw
Feb 11, 2003 06:33 PM
ViZ
Nov 5, 2002 10:15 AM
