**Accu-turn Model 326S Swing Arm Tire Changer** Excellent condition!
Accu-turn Model 326S Swing Arm Tire Changer.
26” Outside clamping capacity standard.
Three-position adjustable bead-breaker accommodates large wheels and tires.
Designed to provide maximum rigidity and torque.
High-performance mount/demount head with tire iron slot designed for low-profile tires.
Features adjustable non-opposing jaws with inflation jets.
Following Arm (FA) assist (Included) applies additional pressure points to easily mount difficult tire.
Specifications:
Inside Clamping: 12-28";
Outside Clamping: 10-26";
Rim/Tire Width: 12";
Rim Width: 15";
Tire Diameter: 44";
Bead Breaker Capacity: 18";
Air Pressure: 100-170 PSI;
HP Motor: 1;
Electrical: 120V 20amp;
Weight: 500 lbs.
5 year Transmission Warranty.
Used for only 2 years. Excellent working condition and makes changing tires an easy job. My asking price is $4300.00 obo. NO LOWBALL OFFERS as you know this machine retails for well over $5300.00 brand new. Let me know if you're interested by calling me directly at (510) 304-3216. Thank you!
Specifications:
Rim Width: 15";
Tire Diameter: 44";
HP Motor: 1;
Weight: 500 lbs.
