NEED HELP ABOUT TO SELL CAR!!!
I am about to sell my car, but when i drove it last night while i was driving the cluster light turns off on me, and now whenever i turn on my headlights the cluster doesn't turn on, but when i press the alarm the cluster light would light up as its suppose to. what could be wrong? if you need to know its a 95 civic si with a stock si cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3tromanc3r »</TD></TR><TR><TD CLASS="quote">nope no wiring done recently. and i tried smackin it and nothing turns back on. </TD></TR></TABLE>
did you try checking the plugs on the back....maybe they are losing connection
dimmer switch, went bad in my car jus cut and twist the black and red wires together on the bak. there is blak red and green i think, jus the red and blak together or new dimmer switch.
it wasnt the dimmer switch, and now my foglights and city lights are also not working. whats going on here! im not good with electrical items to a car but im sure someone here is! please help me. if you got a shop or something that can fix my problems in the bay area please let me know!
which fuse should i check? i already checked the fuse for my cluster and it was fine. and for the ground should i re ground my wires to test if it works?
nothing wrong with any fuse, my fog lights and city lights are wired directly to my corner lights, so there is no extra fuse for the fogs and no switch i need to press.
