Modifying Sensor signal to ECU
Old Aug 17, 2007 | 09:10 AM
Racebrewer's Avatar
Default Modifying Sensor signal to ECU
Hi Guys,
I've taken some long trips in the R recently and was thinking that it might be a good thing to be able to lean it down a bit while cruising in closed loop.
Does anyone know if changing the voltage (between the primary O2 sensor and the ECU) using potentiometers would give me the result I'm looking for?
I have a wideband and an EGT ready to hook in.
Thanks,
John
Sedwards1200
Sep 3, 2016 03:31 AM
jdreyer972
May 1, 2015 09:45 AM
portfl0w
Apr 17, 2007 09:12 PM
ckkl
Mar 10, 2002 03:44 AM
