Front Sway Bar Down Grade
Old Aug 17, 2007 | 07:27 AM
AlienKrOZ's Avatar
Default Front Sway Bar Down Grade
looking to drop the front sway bar size a bit to the Integra LS one. anyone know if this is a easy install?
Old Aug 17, 2007 | 08:00 AM
cjames235's Avatar
Default Re: Front Sway Bar Down Grade (AlienKrOZ)
its as easy as any other front sway bar install...... just be sure to get the smaller bushings for the smaller sway bar
Old Aug 17, 2007 | 08:06 AM
AlienKrOZ's Avatar
Default Re: Front Sway Bar Down Grade (cjames235)
is there anything in the way since my motor and everything is still there? i heard theres alot of crap to unbolt.
Old Aug 17, 2007 | 11:10 AM
migs's Avatar
Downgrade by unbolting one of the endlinks. You will love the handling then.
Old Aug 17, 2007 | 11:51 AM
JjuuN R's Avatar
Your header will be the only thing that kind of gets in your way, doesn't have to be unbolted though.
Old Aug 17, 2007 | 12:20 PM
thtguybryan's Avatar
Default Re: (JjuuN R)
I'll trade you my LS one for your R!
Old Aug 17, 2007 | 12:41 PM
migs's Avatar
Default Re: (thtguybryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thtguybryan &raquo;</TD></TR><TR><TD CLASS="quote">I'll trade you my LS one for your R! </TD></TR></TABLE>
Why? Goodness do you realize what it would do to your handling (Assuming your rear bar is stock)? You would have a crap load of UNDERSTEER.
Old Aug 17, 2007 | 12:57 PM
AlienKrOZ's Avatar
if you pay for shipping
Old Aug 17, 2007 | 01:13 PM
igyloo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">is there anything in the way since my motor and everything is still there? i heard theres alot of crap to unbolt.</TD></TR></TABLE>
shifter linkage and exhaust
Old Aug 17, 2007 | 01:16 PM
Dave-ROR's Avatar
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">
Why? Goodness do you realize what it would do to your handling (Assuming your rear bar is stock)? You would have a crap load of UNDERSTEER.</TD></TR></TABLE>
Shhh.. dude.. R &gt; * always.
duh.
Old Aug 18, 2007 | 07:53 AM
stumpyf4's Avatar
Default Re: Front Sway Bar Down Grade (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Downgrade by unbolting one of the endlinks. You will love the handling then.</TD></TR></TABLE>
Good advice!! Cost nothing except 5min of your time.
Old Aug 18, 2007 | 11:39 AM
AlienKrOZ's Avatar
Default Re: Front Sway Bar Down Grade (stumpyf4)
why unbolt one of them? so it will feel like it's not on there?
Old Aug 18, 2007 | 11:41 AM
JjuuN R's Avatar
Precisely...
Old Aug 18, 2007 | 02:19 PM
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Why? Goodness do you realize what it would do to your handling (Assuming your rear bar is stock)? You would have a crap load of UNDERSTEER.</TD></TR></TABLE>
Well, you know what they say about assuming. I have a 23mm ITR rear sway with an ASR rear subframe brace.
Ok I'm joking, as I was about trading. I know what the consequences of upgrading the front and not the rear sway bar are, and I couldn't handle that haha.
Old Aug 18, 2007 | 02:22 PM
davidnyc's Avatar
Just be REAL careful when undoing the front sway.... On my ITR (800lbF/950lbR springs), the car is relatively stable for a highly sprung car.... I finally unbolted the front sway. Things were going very well, until one heavy braking in a turn. I must of had the car slightly turned and I immediately went sideways and flatspotted my tires. Luckily no damage except tires.
Basically, what I am saying is that for the street, no front bar may be a little dangerous. So your original thought of a LS bar may be better.
Old Aug 18, 2007 | 03:56 PM
DSEA2's Avatar
Default Re: Front Sway Bar Down Grade (igyloo)
what size is the front sway bar on the type rs?
Old Aug 19, 2007 | 12:12 AM
AlienKrOZ's Avatar
Default Re: Front Sway Bar Down Grade (SpoonDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonDC4 &raquo;</TD></TR><TR><TD CLASS="quote">what size is the front sway bar on the type rs?</TD></TR></TABLE>
i think GSR and ITR's are 24 and stock integra is 21? i believe the civic are like 17 or 19? not to sure tho.
Old Aug 19, 2007 | 03:18 AM
d8168055's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">looking to drop the front sway bar size a bit to the Integra LS one. anyone know if this is a easy install?</TD></TR></TABLE>
so, im guessing that a thinner front sway bar will help the turn in, ie increase the amount of oversteer? Sorry, i been out of the honda scene for 3 years...
Old Aug 19, 2007 | 06:08 AM
supra360's Avatar
you should just get a thicker one for the back
Old Aug 19, 2007 | 06:32 AM
AlienKrOZ's Avatar
Default Re: Front Sway Bar Down Grade (supra360)
might get the JDM sway bar. it's a 1mm upgrade.
Old Aug 19, 2007 | 07:21 AM
Doespike's Avatar
i think GSR and ITR's are 24 and stock integra is 21? i believe the civic are like 17 or 19? not to sure tho.</TD></TR></TABLE>
FWIW. For 2001 at least, the LS, GS (mine), and GS-R front sways were all 24mm.
Old Aug 19, 2007 | 07:39 AM
Hooch'n's Avatar
https://honda-tech.com/zerothread?id=1954319
I put a post up a couple months back about the front bar...I have LS front and Stock ITR rear.
Running Skunk 2 coilovers.......hope to get some PIC's for the car 12k/14k to help rotate.
I'll make an update, but i have not felt a big differance with front 22mm.
DarkBB4
Jan 14, 2005 03:56 PM
unknown2
Sep 2, 2004 06:29 PM
ITR Demon
Aug 1, 2003 10:35 AM
LSRydeR
Apr 9, 2003 08:36 PM
