Gearing question for the Honda Tech Gods :)
Old Aug 17, 2007 | 06:08 AM
slow96coupe's Avatar
Default Gearing question for the Honda Tech Gods :)
I am running a USDM ITR tranny... I have been mostly told that I need to be crossing the finish at the top of 4th. Is this the case?
I'm Running 24.5 slicks hitting the rev limiter right before the traps in 4th.
Should I install a LS final drive on my type-r Diff?
Old Aug 17, 2007 | 06:14 AM
TheWickedOne's Avatar
Default Re: Gearing question for the Honda Tech Gods :) (slow96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96coupe &raquo;</TD></TR><TR><TD CLASS="quote">I am running a USDM ITR tranny... I have been mostly told that I need to be crossing the finish at the top of 4th. Is this the case?
Should I install a LS final drive on my type-r Diff? </TD></TR></TABLE>
Yes, that is the case
Bring up the rev-limiter - Case closed..
k thx bye
Old Aug 17, 2007 | 06:22 AM
Rev limiter was at 8500... were gona raise it to 9000.
My motor does have springs and retainers...
Old Aug 17, 2007 | 06:30 AM
Default Re: (slow96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96coupe &raquo;</TD></TR><TR><TD CLASS="quote">Rev limiter was at 8500... were gona raise it to 9000.
My motor does have springs and retainers... </TD></TR></TABLE>
Bring it on up!!!
Old Aug 17, 2007 | 06:52 AM
DaveF's Avatar
Default Re: (TheWickedOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWickedOne &raquo;</TD></TR><TR><TD CLASS="quote">
Bring it on up!!! </TD></TR></TABLE>
Old Aug 17, 2007 | 07:02 AM
turbotypeR@SPEC's Avatar
25 Year Member
You need an MFactory 4.05 FD
Old Aug 17, 2007 | 07:05 AM
RTW DC2R's Avatar
I didnt think the LS final drive fits on an ITR diff?? maybe try the MF 4.05 which was really nice in my ITR trans.
If the motor can handle the extra RPM, try that. otherwise maybe throw in a GSR 4th to make it a bit longer, assuming its compatible with the B16/ITR trans.
Old Aug 17, 2007 | 08:02 AM
fast is fun's Avatar
http://www.f-body.org/gears/
raise it up. 4.05 will make a slow pig the ls 4.26 gsr 4.40 itr 4.70 ?
Old Aug 17, 2007 | 08:36 AM
25 Year Member
Default Re: Gearing question for the Honda Tech Gods :) (fast is fun)
yeah, mine is a slow pig
Old Aug 17, 2007 | 08:45 AM
DaveF's Avatar
Default Re: Gearing question for the Honda Tech Gods :) (turbotypeR@SPEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC &raquo;</TD></TR><TR><TD CLASS="quote">yeah, mine is a slow pig</TD></TR></TABLE>
4.05 is just crazy......
@ 10500 on a 24.5inch tire, you are looking at 170mph in 4th gear....
you let me know when that happens
even @ 9500 you are still looking at 154mph....
@ 10,000- 162mph..
with most of the setups out there today, they are still making/holding power past 9500.
the taller final will accelerate quicker.
you say you dont want to rev that high? well what happens when you fall out of power between gears ? you lose.
Old Aug 17, 2007 | 09:13 AM
RTW DC2R's Avatar
24.5" tire, 4.05FD, ITR trans:
Gear Shift RPM Speed @ 8500 RPM
1st N/A 47.4
2nd 5539 72.7
3rd 5887 104.9
4th 6454 138.2
5th 6511 180.4
RPM in top gear at 75 mph: 3534
same setup at 9000RPM:
4th gear 146.3MPH
I think he could run the 4.05FD but its not going to be the best option at his power level and would be better with a higher rev limit or other OEM FD/gearing. Hes probably got enough power to trap low 130s so he will still have some wasted RPM/MPH left in 4th gear.
Old Aug 17, 2007 | 09:30 AM
DaveF's Avatar
Default Re: (RTW DC2R)
i still say the 4.0 is silly, you are going to need more power to go the same e.t.
just bumping the rpm up 500 from 8500 to 9,000 with the 4.4/24.5 will allow him for 134-135mph. also, it will help recover between shifts, being that its most likely going to drop down into a larger power area, then say when he shifts from 8500.
Old Aug 17, 2007 | 09:35 AM
25 Year Member
Default Re: (dturbocivic)
I rev my car to 9500 with 24.5 inch tire and i am right at the rev imiter in 4th. It does not fall off between gears, and is blowing the tires off on the bottom end.
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96coupe &raquo;</TD></TR><TR><TD CLASS="quote">I trapped 134 on an 11.29 pass w/ a 1.74 60..
Old Aug 17, 2007 | 09:36 AM
I spoke with kevin (projekteg) and he said we were going to try to take it to 9K... he told me to keep my shift points the same but streatch it in 4th...
Too bad you can't do gear based rev limts
Old Aug 17, 2007 | 09:37 AM
Victor Vaughn's Avatar
Default Re: Gearing question for the Honda Tech Gods :) (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
@ 10,000- 162mph..
you say you dont want to rev that high? well what happens when you fall out of power between gears ? you lose. </TD></TR></TABLE>
You sir are correct!
Old Aug 17, 2007 | 09:38 AM
that was shipping into 5th early (trapping 134)
Old Aug 17, 2007 | 09:39 AM
DaveF's Avatar
Default Re: (turbotypeR@SPEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC &raquo;</TD></TR><TR><TD CLASS="quote">I rev my car to 9500 with 24.5 inch tire and i am right at eh rev imiter in 4th. It does not fall off between gears, and is blowing the tires off on the bottom end. </TD></TR></TABLE>
how large is your power band? what does the rpm drop to between gears? have you taken this into consideration? where is your dyno chart? boost control/tire pressure/suspension are huge. this is where the fine tuning counts !
reguardless of what you say.... im going to have to say when you switch gears, you drop to a smaller "power bracket" than if you would rev it up another 500 rpms... you will go slower this way. (unless your power "curve" happens to be flat from 7,000-9500... which im doubting)
boostedcivicsir's Avatar
Mr. Badwrench
thought type r ring =gsr ring
b16 ring =ls ring
as in bolt spacing. not ratio.
if i remember the ls ring wont fit the type r diff.
i know for a fact gsr wont fit b16.
Old Aug 17, 2007 | 09:41 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96coupe &raquo;</TD></TR><TR><TD CLASS="quote">that was shipping into 5th early</TD></TR></TABLE>
going by that.. im going to say your car is capable of traping over 135, and you will hit the limiter of 9,000 before the traps as well. maybe you want to take it up another 250. to 9250 to play it safe. this will also drop you into more power between gears.
DaveF's Avatar
Default Re: Gearing question for the Honda Tech Gods :) (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
if i remember the ls ring wont fit the type r diff.</TD></TR></TABLE>
you are right
Old Aug 17, 2007 | 09:44 AM
i start making realish power from 5500 till 9K
makes 375 @ 6000 and climbs fast after that... Vtec is set at 5200... we did some pulls with no vtec and some with vtec and moved vtec where the two met (if that makes since)
Tire pressure was at 8PSI and i dont wana tell you guys my suspension... i'll get flamed...
But I will buy some as soon as i have more money
Old Aug 17, 2007 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">going by that.. im going to say your car is capable of traping over 135 </TD></TR></TABLE>
That would be nice lol... 10's on a stock sleeved B16 is gona be badass
Old Aug 17, 2007 | 09:57 AM
Boner_Ben's Avatar
That would be nice lol... 10's on a stock sleeved B16 is gona be badass </TD></TR></TABLE>
&lt;-- Its been done! Time to turn up the boost!
Old Aug 17, 2007 | 10:17 AM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96coupe &raquo;</TD></TR><TR><TD CLASS="quote">I spoke with kevin (projekteg) and he said we were going to try to take it to 9K... he told me to keep my shift points the same but streatch it in 4th...
Too bad you can't do gear based rev limts </TD></TR></TABLE>
Why would you want that...just set the Rev limiter to 9500-9600 RPM and call it a day.
