How to install AC in a b16 crx?!
Can u guys please help me, get ac back in my car. Texas is so hot. Please tell me what parts do i need!
can i use my old si ac line?
does any b series compressor would work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaCRXboi »</TD></TR><TR><TD CLASS="quote">Can u guys please help me, get ac back in my car. Texas is so hot. Please tell me what parts do i need!
does any b series compressor would work?</TD></TR></TABLE>
Here is what you need:
Hasport B-Series Ac Bracket This Bracket
Stock Crx Ac Compressor
Stock Crx Condensor
Stock Crx Evaporator
Stock Crx Ac Lines
Stock Crx Condensor
Stock Crx Ac Lines
Honda used two different manufacturers for the compressors in our cars. One was the Sanden and the other was Mitsu (or something like that).
The AC hoses that hook up to the compressor have to match the compressor. In other words, if the hoses originally hooked up to a Sanden, then you have to use the Sanden.
Wes
Wes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xanonymousx »</TD></TR><TR><TD CLASS="quote">
Stock Crx Condensor
Stock Crx Ac Lines</TD></TR></TABLE>
x2 what it did...worked great
Stock Crx Condensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V »</TD></TR><TR><TD CLASS="quote">Honda used two different manufacturers for the compressors in our cars. One was the Sanden and the other was Mitsu (or something like that).
Wes </TD></TR></TABLE>
Matsushita. Make sure you get the right one, because I believe the two are not compatible with each other. The Matsushita one tends to be more expensive and harder to come by/
Modified by bradley_80 at 10:32 AM 8/17/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradley_80 »</TD></TR><TR><TD CLASS="quote">
Matsushita. Make sure you get the right one, because I believe the two are compatible with each other. The Matsushita one tends to be more expensive and harder to come by/</TD></TR></TABLE>did you mean "not" compatible? - they aren't - they have different brackets and different lines
Stock Crx Condensor
you will also need to figure out what you want to do about the a/c fan. b series headers make it impossible to use a stock fan so a half size radiator and/or slim fan is a must.
Stock Crx Condensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacoop86 »</TD></TR><TR><TD CLASS="quote">
you will also need to figure out what you want to do about the a/c fan. b series headers make it impossible to use a stock fan so a half size radiator and/or slim fan is a must.</TD></TR></TABLE>
Very good point. Most of the time you'll have to use a slim fan setup.
CRseXy
Jun 21, 2005 01:40 PM
