NEED help I need h23 and h23 head bolt lenths
Old Aug 16, 2007 | 08:47 PM
ismkv8s's Avatar
Default NEED help I need h23 and h23 head bolt lenths
I have a set of each and I'm not sure what is what.Plz HELP Thanks
Old Aug 16, 2007 | 09:01 PM
Hawkze_2.3's Avatar
Default Re: NEED help I need h23 and h23 head bolt lenths (ismkv8s)
What? You mean H23 and H22?
Old Aug 16, 2007 | 09:13 PM
ismkv8s's Avatar
Default Re: NEED help I need h23 and h23 head bolt lenths (Hawkze_2.3)
Yeah I have a set of each but my wonderfully helpful 3year old daughter was playing with them and now it looks like one big set of boths. And then she look daddy I put them all together for you. How can you get made she thought she was helping.
Old Aug 16, 2007 | 09:23 PM
Hawkze_2.3's Avatar
I have some ARP head studs for an H23 I could measure but that probably wouldn't be the same as bolts...I know one of them is longer than the others though.
Old Aug 17, 2007 | 02:32 AM
Rosko's Avatar
yeah the H22's should all be the same length, so if you take the 10 that are the same length then those should be the H22's
then that leaves you with the 9 + 1 (longer) for the H23
Old Aug 17, 2007 | 05:12 AM
ismkv8s's Avatar
Default Re: NEED help I need h23 and h23 head bolt lenths (Rosko)
Thanks that what I thought but just wanted to make sure.
Old Nov 21, 2013 | 04:27 PM
Tattoojoe Davis's Avatar
i need to know in inch'
s how long the H23 head bolts are?
Old Nov 21, 2013 | 05:16 PM
Sparksman's Avatar
Hey mister first post, you realize you just replied to a 7 year old thread.... Nobody has said anything in almost a decade on this thread.
Why do you need to know length? F series and the H23 share the same head studs, and the H22 has its own size. Use the correct studs for the head you need and you will be fine.
The Destroyer
Mar 20, 2011 03:11 PM
f23__
May 7, 2007 10:40 AM
championshipwhite93si
Jul 31, 2006 07:56 PM
littleredhatch
Dec 5, 2002 05:49 AM
