00 civic ex turbo
Old Aug 16, 2007 | 08:31 PM
thong84's Avatar
Default 00 civic ex turbo
i know this might be a noob question but i just have to know. im running hondata s100 w/ b and the setting is for 440cc with the base map settings. my tuner can't tune it cuzz he doesn't have the code. i don't know what code, some kind of code to log into hondata tuner program i think. but my question is, is it ok to run my car just for a little while on my turbo ex on 450cc with the p28 at basemap including 440cc settings in hondata. untuned p28.
Old Aug 16, 2007 | 08:35 PM
Syndacate's Avatar
Default Re: 00 civic ex turbo (thong84)
Depends how you define "little while" - I wouldn't, and I certainly wouldn't let that turbo spool up .
Old Aug 16, 2007 | 08:43 PM
94c1v1cex's Avatar
as long as that turbo never sees spool (which will be hard, try getting onto an onramp in a hurry without spoolin that thing up) you should be fine
Old Aug 16, 2007 | 08:48 PM
Syndacate's Avatar
Default Re: 00 civic ex turbo (94c1v1cex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">as long as that turbo never sees spool (which will be hard, try getting onto an onramp in a hurry without spoolin that thing up) you should be fine</TD></TR></TABLE>
Actually if I were him I'd disconnect the charge pipe so boost doesn't reach the motor.
Then it shouldn't matter as long as you're running 440 injectors and the Hondata is tuned for 440's. You can fine tune it when you get it to a dyno and that's where you can put the charge pipe back on too.
Old Aug 16, 2007 | 08:53 PM
94c1v1cex's Avatar
Default Re: 00 civic ex turbo (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Actually if I were him I'd disconnect the charge pipe so boost doesn't reach the motor.
Then it shouldn't matter as long as you're running 440 injectors and the Hondata is tuned for 440's. You can fine tune it when you get it to a dyno and that's where you can put the charge pipe back on too.</TD></TR></TABLE>
ya also don't wanna overspin the turbo.... sounds weird but it happens
Old Aug 16, 2007 | 08:55 PM
Syndacate's Avatar
ya also don't wanna overspin the turbo.... sounds weird but it happens</TD></TR></TABLE>
It shouldn't if your coolant lines are connected properly and your wastegate is fully operational.
Are you using an internal gate or an external gate?
Old Aug 16, 2007 | 09:35 PM
thong84's Avatar
im using an external wastegate
Old Aug 16, 2007 | 09:45 PM
thong84's Avatar
my coolant lines are fine. i never touched it in my turbo setup. i left it alone for now. but also about my wastegate. it won't open for some reason. its suppose to be a 6 or 7psi but it goes to 9 and 10. they say its the spring but im still not sure. before i brought it to the shop i installed the turbo and just ran it for like 2 months till i got time to get it tune. didnt run shitty either other than at high *** rpm, white smoke comes out. lol
Old Aug 16, 2007 | 09:51 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thong84 &raquo;</TD></TR><TR><TD CLASS="quote">my coolant lines are fine. i never touched it in my turbo setup. i left it alone for now. but also about my wastegate. it won't open for some reason. its suppose to be a 6 or 7psi but it goes to 9 and 10. they say its the spring but im still not sure. before i brought it to the shop i installed the turbo and just ran it for like 2 months till i got time to get it tune. didnt run shitty either other than at high *** rpm, white smoke comes out. lol </TD></TR></TABLE>
White smoke eh? You probably smoked a gasket running it untuned.
If it's an external gate and it's supposed to be 6 or 7 and it's running 9 or 10 then it's definitely your spring.
If you're using an external gate it shouldn't be spiking....well it shouldn't be spiking ever, but spikes 9 times outta 10 are with internal gates, not external.
I'd get that spring checked, see where you r from there.
Old Aug 16, 2007 | 09:52 PM
94c1v1cex's Avatar
eh... that's not good
Old Aug 16, 2007 | 09:58 PM
thong84's Avatar
yea i know it wasn't good but i still drove it and everything was fine. i just got it back from the shop and 450's are in and p28 hondata is in but its not tuned on the dyno yet cuzz they don't have the code for hondata program to tune. reved it up and everything seems fine but i just don't wanna blow it.
Old Aug 16, 2007 | 09:59 PM
thong84's Avatar
is there anyway that anyone has or can get the hondata code to get into the hondata program
Old Aug 16, 2007 | 10:14 PM
thong84's Avatar
oh yea and even though my wastegate goes up to 9 or 10 it still wont open. nothing comes out of the dump tube
Old Aug 16, 2007 | 10:20 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thong84 &raquo;</TD></TR><TR><TD CLASS="quote">oh yea and even though my wastegate goes up to 9 or 10 it still wont open. nothing comes out of the dump tube</TD></TR></TABLE>
What do you mean it's not opening? If it's not opening it'll keep climbing - it won't stop at 9 or 10 psi unless you're hitting 9/10 psi boost peak at your redline.
Old Aug 16, 2007 | 10:35 PM
94c1v1cex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean it's not opening? If it's not opening it'll keep climbing - it won't stop at 9 or 10 psi unless you're hitting 9/10 psi boost peak at your redline.</TD></TR></TABLE>
which would suck lol
Old Aug 17, 2007 | 12:18 AM
Syndacate's Avatar
which would suck lol</TD></TR></TABLE>
Eh, yeah...for a performance (power) turbo it would.
Though for an economy turbo like that S20 or whatever on the 1.8T Jettas it's kinda normal.
Old Aug 17, 2007 | 12:49 AM
k powered ej1
Guest
Posts: n/a
wastegate.........................those turbos arent that small <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Eh, yeah...for a performance (power) turbo it would.
Though for an economy turbo like that S20 or whatever on the 1.8T Jettas it's kinda normal.</TD></TR></TABLE>
Old Aug 17, 2007 | 12:51 AM
highrev1987's Avatar
Default Re: 00 civic ex turbo (k powered ej1)
internal gate is not worth it, invest in a t3 flanged external gate setup, that gives you more posibilities
Old Aug 17, 2007 | 12:55 AM
k powered ej1
Guest
Posts: n/a
my guess if the waste gate is still functional the previous onwer installed a longer vacumn line to get it to a lsightly higher psi like that, go ahead and get a smaller line or cut the line it should see 7 again
qhiggy
Jan 7, 2013 12:53 PM
slammeddime
Engine Management and Tuning
Sep 4, 2011 07:38 AM
eg underclassman
Oct 18, 2006 09:34 AM
hatch_b18
10
Mar 30, 2006 12:21 PM
B18C4-T
Jun 9, 2002 11:34 PM
