Clutchnet not disengaging?
Old Jun 12, 2002 | 09:14 PM
Mochanic's Avatar
Default Clutchnet not disengaging?
Have any of you had a new clutchnet clutch not disengage when the pedal is pushed in?
Yes, everything is installed correctly, and the slave cylinder moves as much as it should!
BTW, its in a 98 Type R.
Old Jun 12, 2002 | 09:15 PM
Kamin's Avatar
Default Re: Clutchnet not disengaging? (Mochanic)
bleed it
sounds like air in the system
Old Jun 13, 2002 | 12:20 AM
Rocket's Avatar
Default Re: Clutchnet not disengaging? (KAMiN)
Call Clutchnet and chew them out.
Old Jun 13, 2002 | 03:52 AM
kinesistech's Avatar
Are you sure you didnt forget the throwout bearing. Unless your pressure plate is jacked I dont see how EVERYTHING is installed correctly and still dont work.
deeweezy187
Apr 16, 2008 09:56 AM
judonoh
Aug 5, 2005 05:45 PM
fridexter
11
May 27, 2005 01:19 AM
boosted350z
Dec 5, 2004 06:07 PM
Integra99
Oct 4, 2004 04:17 PM
