b20z2 distributor wiring question
first background
98 civic ex with i believe a dx wire harness. has a b20z2 motor in it that needs the wiring done. owner of the car sold his ex harness by mistake(thought he had to use an integra one) and i am using the dx one to wire it up.
Ok I've been searching this forum for the past two days but have yet to find a thread that tells me how am i suppose to wire the b20z2 distributor into a ek harness. i saw one person post up how he did it on an b16 si motor but the wire colors are different on my distributor. ill add two basic pics of what im working with here. if you need more pics just let me know and i can take a pic of every wire if you need it.
b20z2 distributor
stock style plug distributor
b20z2 distributor
Guest
Posts: n/a
what you need to do is get the plug that fits the wiring harness and then cut the one off the dizzy and match the colors and solder it up cuz i have a ek with a b20z (obd2 motor) and a obd1 head and dizzy so i had to do this to works good cuz you have a obd2b dizzy and you need a obd2a plug easy fix
BrothaSit
Jan 5, 2011 06:19 PM
