Help!!! WHITE SMOKE... Not blown head gasket.
Well today I changed my header and put a high flow cat conveter, my tranny Oil and SH oil. Well that all went well, but when I started it alot of whiteish blueish Oil from my exhaust. SO i thought it will go away after a few min's, Well it didnt. It's ALOT of smoke for a four banger so any advise would help.
Please no flaming, thanx for any input.
ok, so how is it posible that every thing was a 100% good until I did this tune up? Dono im gona go right now drive car for 10-15 min see if anything gets better, thanx for help
Well When i whent to go for a ride. I started it and it was 100% perfect. No smoke at ALL. So i drove it for a while hit Vtec a few times and then for like 2 min there was ALOT of white smoke again. After thows 2 min it whent back to normal. Any Ideas?
Here's a long shot: A long, long time ago, I had a brake booster that was failing at the master cylinder side. The engine's vacuum was strong enough to suck brake fluid from the master cylinder, into the booster, then into the engine's intake via the booster's hose! It was easy to figure out the problem, because the smoke got really bad whenever I pressed on the brakes. Point is that engine oil isn't the only oil you could be burning...
Redprelude98
Nov 25, 2008 10:42 AM
blue89hatch
May 7, 2008 06:29 PM
