How To - Hook up aftermarket Horn
Old Aug 16, 2007 | 03:43 PM
Honda_Accord's Avatar
Default How To - Hook up aftermarket Horn
Ok so i searched alot of places for this and it seems like a lot of people had different answers and suggestions. Most of the visuals were for tegs and civics and nothing for Accord. So I thought id write something up for us, its not the best probably, im not a big wire , electrtion type person, but i did my best!.
I hooked up the horn. I read that most negs. are in the middle of the horn and the pos. is at the edge if you got a two prong horn.
I ran the wire and grounded it to a metal spot that met the chassis of the car. The part you see in the pic is where the Automatic shift lever would connect.
Here you see where i ran it to. Its more explanatory when you actually get your car apart
Some of the pics and threads I found most of them you had to hook up one wire to a 6 pin yellow connector, Well my car didn't have that so i researched a little more and found out that the horn is a blue with red strip wire, well this connector.
As you can see the red and blue wire is visible on this connector, It should be under above the steering column
As you can see i ran the positive from last connector on the left where it would meet up with the red and blue wire.
Here you see it all hooked up. I pressed the horn button and BAM it honked, started the car and it honked.
it was pretty easy once i researched on here a bit more, just thought id show the fellow accord people about it, sense it seems alot didn't know much about it. Hope this helps and any criticism and suggestions are welcome
ps. I didnt put the steering wheel on and all that, because i have a burnt bulb in my cluster so i just left my steering wheel off to get to it easier.
pliskin8
Aug 23, 2011 02:53 PM
YoungKadafi
Audio / Security / Video
Apr 16, 2007 06:53 PM
littledragon_79
Jan 19, 2007 03:18 PM
dylokjai
14
Oct 13, 2006 01:10 PM
Brewer
Sep 18, 2002 11:09 AM
