Setting Vtec?
Old Aug 16, 2007 | 03:28 PM
DETOUR180's Avatar
Default Setting Vtec?
What RPM do you guys set your vtec to kick in at in a lsvtec and b20vtec motor?
Most of my friend like it at 5000RPM. What do you guys suggest?
Old Aug 16, 2007 | 03:34 PM
96Spec Ek's Avatar
Default Re: Setting Vtec? (DETOUR180)
Depends what cams and manifold you're using.
Old Aug 16, 2007 | 04:14 PM
Jay_Sensing's Avatar
The only real way to set it to the smoothest transition is on a dyno man. Every motor will be different.
You can get it close from copying someone else with a similar setup but it probably won't be dead on.
TurboEG6262
Mar 8, 2013 12:39 PM
honda_ek9
14
Jun 7, 2009 04:42 PM
rdeezy78
Sep 12, 2006 03:29 PM
turbo Si
Jun 8, 2003 05:02 AM
DualKnuttz
12
Feb 22, 2003 02:25 PM
