car idles at high rpm!!
Old Aug 16, 2007 | 01:37 PM
mcc361's Avatar
Default car idles at high rpm!!
ok my friend wants to buy a civic si hatchback and the guy wants 3k for it but it idles at high rpm when cold!! is it worth buying for this much? how much would it be to fix the problem?
by the way anyone know what the f*** these rings are !!! looks like ****
Modified by mcc361 at 3:40 PM 8/16/2007
Old Aug 16, 2007 | 01:45 PM
crazyguy's Avatar
Default Re: car idles at high rpm!! (mcc361)
3k for a si eg hatch.is the body shap in good condition?3k sounds a bit pricy to me and u can adjust the idel screw to the normal idel.
Old Aug 16, 2007 | 01:51 PM
del sol b18c's Avatar
Default Re: car idles at high rpm!! (crazyguy)
the idle screw isn't going to do anything, it's at cold idle, my car does the same thing but after a while it starts to surge up and down, i cleaned my iacv but that didn't do anything. idles fine when warm though.
Old Aug 16, 2007 | 01:53 PM
98greensi's Avatar
Default Re: car idles at high rpm!! (del sol b18c)
check the small ground wires by the thremostat for your surging problem i had 2 friends cars that did that and all it was that the wires were about to fall off and was making a real shitty connection, it fixed thier problem
Old Aug 16, 2007 | 02:44 PM
nekoabandoned's Avatar
Default Re: car idles at high rpm!! (98greensi)
vacuum leak ftw, sometimes when theres a vacuum leak people turn up the idle to keep the car running. if they did that it would idle high at start up maybe even 3k+ rpm, but after warm up itll have a idle surge . pinch the all the vaccum lines one at a time and see if the idle levels out and or rises ,holds after warm up . of coarse check by eye for any lines that are not connected.
DO/\/\O
14
May 9, 2011 05:56 PM
still4punk
Mar 5, 2009 03:46 PM
bb4 jdm lude
Mar 12, 2008 09:25 AM
TheNasty0ne
Dec 17, 2005 01:07 PM
jokr78
Dec 15, 2004 01:47 PM
