Anybody have JG cam gears?????
Old Jun 12, 2002 | 08:27 PM
LB CRX's Avatar
Default Anybody have JG cam gears?????
Where is the TDC point on these gears? each sprocket has a line and a dot. i was told that i was supposed to line up the dots so that they were horizontal to eachother. the closest it gets is where the dot on the intake cam is slightly lower than the one on the exhaust cam. the dot on the exhaust cam is lined exactly with the point on the top surface of the head. DOES ANYBODY HAVE THESE SPROCKETS?
TIA
Old Jun 12, 2002 | 10:43 PM
MikeSarr_GSR's Avatar
Default Re: Anybody have JG cam gears????? (LB CRX)
VTEC
Variable Valve Timing and
Electronic Control
V-Tech is a phone
Modified by MikeSarr_GSR at 3:49 PM 5/12/2007
Old Jun 14, 2002 | 11:32 AM
Rocket's Avatar
If your head has been milled this will happen. The cams have to roll back to take up slack.
Hope this helps. This happens all the time. It' means your cam timing is slightly retarded.
hon2984
Jan 18, 2008 11:35 AM
customx_
Oct 5, 2002 10:17 AM
3rdGteg
Jan 6, 2002 04:44 AM
