IS THIS A Vacuum Leak and possibly why im getting a CODE 5 to the MAP sensor?.. please read...
Old Aug 16, 2007 | 11:07 AM
david22ky's Avatar
Default IS THIS A Vacuum Leak and possibly why im getting a CODE 5 to the MAP sensor?.. please read...
ok i was dow nthere at my car and gettin a code 5 for map sensor.. ok.. well i think this is what u call the "charcoal" canister its hooked up to.. but the input to the canister was plugged off?!...
so should i just do this..
just run me a vacuum ose from the point its got a open line to the plugged one.. i mean to me.. IT MAKES sense..
someone please help me im right in the middle of ALMOST getting this car to run right..
cause i figure with that being plugged off..its not getting a TRUE signal to my MAP sensor.
Old Aug 16, 2007 | 11:24 AM
david22ky's Avatar
Default Re: IS THIS A Vacuum Leak and possibly why im getting a CODE 5 to the MAP sensor?.. please read... (
anyone? can someone that has a b16 take a pic of theres for me.. all i need is 1 pic PLEASE lol
Old Aug 16, 2007 | 11:27 AM
david22ky's Avatar
Old Aug 16, 2007 | 01:02 PM
david22ky's Avatar
bump someone help me
Old Aug 16, 2007 | 05:43 PM
highrev1987's Avatar
what is that sensor on the firewall??
Old Aug 16, 2007 | 06:11 PM
Hope this helps, this is my car
/\/\ canister
/\/\ Map Sensor
/\/\ no sensor by the fuel lines
/\/\ running and obd0 TB and Mani
/\/\ Map wire colors
/\/\ TPS colors
Check to see if those are reversed and if they are not then check if the map is getting sufficient vacuum, find some one that has another MAP and hook it up to the vacuum line
Old Aug 16, 2007 | 06:17 PM
Luserkid's Avatar
Running the map vac to the charcoal isnt going to help. It needs a vacum. T it off of the intake manifold somewhere. Although when i used to have a firewall map i just left it open like yours is and never had a problem. But T it and see what happens.
Old Aug 16, 2007 | 06:20 PM
david22ky's Avatar
Default Re: (Luserkid)
yeh ive gotten more help then i thought i would outta this i jsut wish someone that was runnig OBD1 intake mani would post me some pics..i do appreicate ALL the help tho guys!!
Old Aug 16, 2007 | 06:22 PM
Default Re: (david22ky)
all the map needs is is vacuum the only diff between yours and mine is that i have the
Map getting vac from a point on the mani, just make sure the wires are right
92ehatch
16
Feb 19, 2007 11:41 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
barry11j
Aug 4, 2004 09:45 AM
DAMCOOLDAV
Sep 12, 2003 02:05 PM
