B20 VTEC w/ B16 head... what to use / replace?
Old Aug 16, 2007 | 11:05 AM
SolAssassin's Avatar
Default B20 VTEC w/ B16 head... what to use / replace?
Before you guys flame me, I have done my best to research this on my own, but still have a few unanswered questions. I have decided to go B20 VTEC and am selling my GSR block + stuff. Do I still use GSR head studs even with a B16 head? In the "reliable LS/VTEC build," he uses a GSR head and an LS block, so I'm not sure whether or not these studs still apply to my build. Also, will I need to replace the B20Z rod bolts? I know that they're weak on the LS blocks, but are they the same situation with B20s as well? And last but not least, I plan on using a block girdle and replacing the 6 torque-to-yield bolts that need to come out to do so. Do I need to use longer bolts, or will the stock CRV bolts still work?
Old Aug 16, 2007 | 11:36 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: B20 VTEC w/ B16 head... what to use / replace? (SolAssassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolAssassin &raquo;</TD></TR><TR><TD CLASS="quote">Before you guys flame me, I have done my best to research this on my own, but still have a few unanswered questions. I have decided to go B20 VTEC and am selling my GSR block + stuff. Do I still use GSR head studs even with a B16 head? In the "reliable LS/VTEC build," he uses a GSR head and an LS block, so I'm not sure whether or not these studs still apply to my build. Also, will I need to replace the B20Z rod bolts? I know that they're weak on the LS blocks, but are they the same situation with B20s as well? And last but not least, I plan on using a block girdle and replacing the 6 torque-to-yield bolts that need to come out to do so. Do I need to use longer bolts, or will the stock CRV bolts still work?</TD></TR></TABLE>
ARP ROD BOLTS are a MUST (but I can't remember if there is a dif size to use on B20 rods.)
Use ARP 208-4306 for head studs (GSR uses 208-4303)
Dunno on the block girdle. Call up Endyn for your part and ask Larry about what to do about ARP bolts for it.
Good luck.
Chris H.
Old Aug 16, 2007 | 05:04 PM
LSVTECJW's Avatar
YEA IM DOIN LSVTEC BUILD AND UNTILL I HAVE MY BOTTOM END BUILT I AINT REVIN PAST 7 GRAND I HAVE HEARD ALL the stories screw that
Old Aug 16, 2007 | 09:50 PM
Combustion Contraption's Avatar
Default Re: B20 VTEC w/ B16 head... what to use / replace? (LSVTECJW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTECJW &raquo;</TD></TR><TR><TD CLASS="quote">I AINT REVIN PAST 7 GRAND I HAVE HEARD ALL the stories screw that</TD></TR></TABLE>
Then youre in for a big disapointment.
Old Aug 16, 2007 | 09:56 PM
Suck my DX's Avatar
Default Re: B20 VTEC w/ B16 head... what to use / replace? (Combustion Contraption)
you can still use the gsr head studs for the b20.
Old Aug 17, 2007 | 03:40 PM
Default Re: B20 VTEC w/ B16 head... what to use / replace? (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">you can still use the gsr head studs for the b20.</TD></TR></TABLE> Thanks a million
Old Aug 20, 2007 | 05:54 AM
Default Re: B20 VTEC w/ B16 head... what to use / replace? (Richard Noggin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Richard Noggin &raquo;</TD></TR><TR><TD CLASS="quote">
I only want to replace these if I have to... are these bolts as weak as the LS bolts or are they decent like GSR rod bolts?
Old Aug 20, 2007 | 10:44 AM
smileycvc's Avatar
They are weak. They are probally the number one issue with b20s.
Old Aug 20, 2007 | 11:48 AM
Golden Eagle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolAssassin &raquo;</TD></TR><TR><TD CLASS="quote">Before you guys flame me, I have done my best to research this on my own, but still have a few unanswered questions. I have decided to go B20 VTEC and am selling my GSR block + stuff. Do I still use GSR head studs even with a B16 head? In the "reliable LS/VTEC build," he uses a GSR head and an LS block, so I'm not sure whether or not these studs still apply to my build. Also, will I need to replace the B20Z rod bolts? I know that they're weak on the LS blocks, but are they the same situation with B20s as well? And last but not least, I plan on using a block girdle and replacing the 6 torque-to-yield bolts that need to come out to do so. Do I need to use longer bolts, or will the stock CRV bolts still work?</TD></TR></TABLE> if you are going to do a block girdle maks sure it is one that has dowled to the mains if not its a wast of time and you really don't need one for a street car we have made 800 hsp on a ls block with out one
Old Aug 20, 2007 | 11:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTECJW &raquo;</TD></TR><TR><TD CLASS="quote">YEA IM DOIN LSVTEC BUILD AND UNTILL I HAVE MY BOTTOM END BUILT I AINT REVIN PAST 7 GRAND I HAVE HEARD ALL the stories screw that</TD></TR></TABLE> i used to take mine to 8.5k no problems had it for 2 years before i sold the car
Old Aug 21, 2007 | 05:16 AM
Default Re: B20 VTEC w/ B16 head... what to use / replace? (Golden Eagle)
was there an issue with the head gaskets in the b20/vtec kit? a lot of people say not to use them and i was wondering why...
if so, has the problem been corrected?
Old Aug 21, 2007 | 07:39 AM
all these guys that say there is a problem with the gasket we use never used our kit. we have had no problems with anyone that has tried our kit. i get calls all the time saying i got the wrong gasket, you sent me a vtec gasket, i tell them the same thing all the time to use it trust me and they do and guess what no leaks no complaint's.
Old Aug 22, 2007 | 08:20 PM
jdmboyef9's Avatar
Please note that the only difference between a B20Vtec build and an LSVtec build is the size of the headgasket.....the B20 and LS blocks are the same size and share the same rods, crank, ect. The only real difference is the size of the pistons, (and the style of sleeves on the B20)
Follow the LSVtec build thread and just use a B20 or +84mm headgasket
Old Aug 23, 2007 | 07:38 AM
Default Re: B20 VTEC w/ B16 head... what to use / replace? (jdmboyef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboyef9 &raquo;</TD></TR><TR><TD CLASS="quote">Please note that the only difference between a B20Vtec build and an LSVtec build is the size of the headgasket.....the B20 and LS blocks are the same size and share the same rods, crank, ect. The only real difference is the size of the pistons, (and the style of sleeves on the B20)
</TD></TR></TABLE> he can not use a b20 gasket with out kit unless he drills out the dowel holes because they are on the opposite side of ware the b20 gasket is set up to use
Old Aug 23, 2007 | 07:42 AM
</TD></TR></TABLE> he can not use a b20 gasket with out kit unless he drills out the dowl holes because they are on the opposite side of ware the b20 gasket is set up to use
Old Aug 23, 2007 | 08:07 AM
I only want to replace these if I have to... are these bolts as weak as the LS bolts or are they decent like GSR rod bolts?</TD></TR></TABLE>
I'm fairly sure they're weak, I'd pay for it.
Old Aug 23, 2007 | 02:00 PM
CeReal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote"> he can not use a b20 gasket with out kit unless he drills out the dowl holes because they are on the opposite side of ware the b20 gasket is set up to use </TD></TR></TABLE>
just to clarify....the OEM b20 head gasket needs modification? and the golden eagle b20 head gasket already has the modification?
Old Aug 23, 2007 | 03:51 PM
Default Re: B20 VTEC w/ B16 head... what to use / replace? (CeReal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeReal &raquo;</TD></TR><TR><TD CLASS="quote">
just to clarify....the OEM b20 head gasket needs modification? and the golden eagle b20 head gasket already has the modification? </TD></TR></TABLE>yes you would need to open the dowel holes to match the vtec head
and ours is ready to go here is a link of how we do it http://www.lightningmotorsport...t.pdf
Old Aug 23, 2007 | 06:03 PM
jdmboyef9's Avatar
The Golden Eagle kit is very good but I don't like the 84mm headgaskets they use. I am personally running one and have not had a problem but I believe that they are an 81mm recut to 84mm, in other words less seal compared to a moddified B20 gasket. If your going for a high compression B20 then I would recommend an aftermarket gasket.
Old Aug 24, 2007 | 07:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboyef9 &raquo;</TD></TR><TR><TD CLASS="quote">The Golden Eagle kit is very good but I don't like the 84mm headgaskets they use. I am personally running one and have not had a problem but I believe that they are an 81mm recut to 84mm, in other words less seal compared to a moddified B20 gasket. If your going for a high compression B20 then I would recommend an aftermarket gasket.</TD></TR></TABLE> eggum runs our 84mm gasket on her car, shes ruining in the 7s on high boost, so trust me there is no sealing problem with our gaskets. they work much better then any aftermarket gasket i have seen. a b20 with high compression will not be a problem
EJ-1
Apr 20, 2010 05:11 PM
civic-8442-
Aug 2, 2009 02:01 PM
b20powereDA
24
Mar 30, 2006 10:18 PM
Miracle_X_Bar
Oct 3, 2003 07:25 PM
MAYHEM
Sep 28, 2003 09:16 PM
