How do you tell gsr cams from b16's?
How do you tell gsr cams from b16 cams? I have only found pics of itrs and ctrs but what do gsr cams have that is different than b16's. Thanks.
Most likely a little more lift and duration on both sides of the cam, cause yer feeding a bigger motor that goes to the same rpm. Exactly HOW much, i don't know. Never really needed that much info. Visually there probably is no way to tell the difference.
curioso
Jan 17, 2010 12:13 PM
