98 spec JDM ITR motor, what cams can i toss in without changing valvetrain?
Old Aug 15, 2007 | 11:12 PM
n1_egsex's Avatar
* B A N N E D *
Default 98 spec JDM ITR motor, what cams can i toss in without changing valvetrain?
just wondering if there are any camshafts that are more aggressive than the 98 spec itr cams, and also safe to use on the stock itr valvetrain
i'll also be getting adjustable cam gears
i'm considering the blox type b's or blox pro-1
Old Aug 15, 2007 | 11:54 PM
1.8L_allmotormilitia's Avatar
maybe stage 1's like skunk2 stage 1.
Old Aug 16, 2007 | 02:32 AM
b20beast978's Avatar
nothing bigger than a stage 1...anything else might put a beating on your valvetrain
Old Aug 16, 2007 | 09:56 AM
ALLphilthyDC2's Avatar
Default Re: (b20beast978)
i think the BC3+ can be used without changing the VT...nice cams for the street too!
Old Aug 16, 2007 | 10:14 AM
UncleD's Avatar
Default Re: (ALLphilthyDC2)
Stock valvetrain/stock cams.
Old Aug 16, 2007 | 12:02 PM
cartune network's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLphilthyDC2 &raquo;</TD></TR><TR><TD CLASS="quote">i think the BC3+ can be used without changing the VT...nice cams for the street too!</TD></TR></TABLE>
maybe but i wouldnt reccomend it. the bc3's are a 295 degree cam with a decent lift. stage 1 anything should be ok with stock valvetrain. but i would upgrade it neway. do it once do it right. get a set of skunk2 springs and retainers or supertech and then choose ur cams.
Old Aug 16, 2007 | 04:45 PM
donnie_437's Avatar
Default Re: 98 spec JDM ITR motor, what cams can i toss in without changing valvetrain? (JJSpecTuning)
anything under 12mm of lift should be ok. type r vavle springs bind at over 12mm lift
sol_1
Nov 11, 2007 10:56 AM
n1_egsex
Aug 16, 2007 09:52 AM
JdMWoRm2
27
Feb 2, 2007 01:44 AM
Greyghostgsrt
Sep 2, 2005 05:10 PM
rocco
33
Feb 16, 2004 01:14 PM
