Help Identify Cams D16A / DOHC ZC
Old Aug 15, 2007 | 11:07 PM
skip.two's Avatar
Default Help Identify Cams D16A / DOHC ZC
I'm sorry if this doesn't belong here, but I searched quite a long time on H-T and Google, and found nothing. Well, my friend pulled some cams from an '87 Integra the other day. He noticed the valve cover was a JDM cover, but couldn't find the engine stamp, so he's not sure if the cams are from a DOHC D16A or brown top DOHC ZC. Here's the pics he sent me:
If more pics need to be specifically provided, then I will have him take more pics.
Old Aug 16, 2007 | 06:37 AM
jlicrx's Avatar
Default Re: Help Identify Cams D16A / DOHC ZC (skip.two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip.two &raquo;</TD></TR><TR><TD CLASS="quote">He noticed the valve cover was a JDM cover, but couldn't find the engine stamp</TD></TR></TABLE>the engine model/serial number stamp on the 87 D16A1 and ZC is on the back of the block right by the starter - runs up and down
Old Aug 16, 2007 | 12:50 PM
skip.two's Avatar
Default Re: Help Identify Cams D16A / DOHC ZC (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">the engine model/serial number stamp on the 87 D16A1 and ZC is on the back of the block right by the starter - runs up and down</TD></TR></TABLE>
Yes, I knew that already, but he didn't. He already pulled the cams from a junkyard Integra, so I don't think he'll be going back there to check. Thanks for trying to helping though.
Old Aug 16, 2007 | 02:10 PM
SIred91's Avatar
Rainman
My bet is on the teg motor.
Old Aug 16, 2007 | 02:16 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Help Identify Cams D16A / DOHC ZC (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">My bet is on the teg motor. </TD></TR></TABLE>
Mine as well. Was he 100% on it being a JDM valve cover? It may just have been super dirty.
Old Aug 16, 2007 | 03:29 PM
jlicrx's Avatar
Default Re: Help Identify Cams D16A / DOHC ZC (wiZCo)
i have a set of 89 D16A1 cams and they both say R2 on them - probably doesn't mean anything, as i believe the 87 had different cams from the 89 - just thought i would throw that out there - i used to have a set of "browntop" JDM DOHC ZC cams, but sold them to some guy with an Integra - should have taken a picture
Old Aug 16, 2007 | 03:50 PM
skip.two's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Mine as well. Was he 100% on it being a JDM valve cover? It may just have been super dirty. </TD></TR></TABLE>
Haha well he said it was a JDM valve cover.
Old Aug 16, 2007 | 10:38 PM
hondasaurusrex's Avatar
can ya get a pic of the cam gears up?? cuz i have both sets of cams...3 sets of jdm black top dohc zc cams, and one set of the dohc d16 cams that my moron buddy pulled off a teg' from a yard not unlike your situation...the zc's cam gears have very spread out "spokes" if you will.....
Old Aug 17, 2007 | 07:59 AM
jlicrx's Avatar
Default Re: Help Identify Cams D16A / DOHC ZC (hondasaurusrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasaurusrex &raquo;</TD></TR><TR><TD CLASS="quote">can ya get a pic of the cam gears up?? cuz i have both sets of cams...3 sets of jdm black top dohc zc cams, and one set of the dohc d16 cams that my moron buddy pulled off a teg' from a yard not unlike your situation...the zc's cam gears have very spread out "spokes" if you will.....</TD></TR></TABLE>wouldn't help - here are pictures of the D16A1 cam gears - 88-89 gear is on the left and 86-87 gear is on the right - the JDM "browntop" DOHC ZC cam gears are like the 86-87 D16A1 gears - 88-91 JDM "blacktop" cam gears are similar to the "browntop" but smaller in diameter - the "browntop" has 40 teeth - the "blacktop" has 34 teeth
Old Aug 19, 2007 | 03:24 PM
XxDarkSidexX's Avatar
do what every person, who has a shred of mechanical sense. Go have the cam spec'ed. Any cam shop will do it. Even if it is a stock came (be it jdm or not) it looks used, and the spec's on the cam could be worn already. There is no way to know for sure unless you have the CAM CARD with cam grinding specs (Lift, duration ect.). Just go get it spec'ed and find out. It is a very common thing to do, having a cam spec'ed.
slate13530
26
Sep 24, 2004 08:28 AM
JDMCRX
Dec 27, 2003 05:40 AM
EP3_05
May 1, 2002 06:41 PM
