Y8 trans pricing
How much would you pay for a ~60k mile Y8 trans in mint condition with a 6 month warranty?
Going rate seems to be about 2-300 for just a Y8 in mint condition, but factor in 60k, and 6 month REPLACEMENT AND INSTALLED (meaning they'll remove and install a new one free of charge) warranty.
How high/low would you go for that?
d series trannys are all over the place... you should be able to find one for alot cheaper than 2-300 but then again having replacement and install... that sounds good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">d series trannys are all over the place... you should be able to find one for alot cheaper than 2-300 but then again having replacement and install... that sounds good</TD></TR></TABLE>
where is the tech???
Search n00b
Search n00b
i wouldn't pay over 150 with replacement and installed, but then again i got my 50k mile tranny for $55. i would say look around, you can find a tranny for alot cheaper. replacing a tranny isn't **** i did it with a jack and hand tools in 2 1/2 hours.
yes there are many D series transmissions all over the place but he most likely wants an EXor"Y8" transmission because it has the closest gear ratio out of all the d series tr4ansmissions and 200-300 for a gaurenteed Y8 trans with only 60K is a good deal.
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
d series trans are all over for 100-200$ all day..labor wise its easily 300-500 $ job and prolly 600+ at honda or big places.
If this is from a shop then heres how the prices are broke down out here.
From a reliable source D series transmission: 350-400 with 3 month replacement.
Labor done by reliable source: 300-600
So your looking at 650 to 1000 for a transmission parts and labor. Now add in your prices compared to So Cal and you should have your answer.
I'm sorry, I wasn't really clear.
This is THEM putting it in (obviously they can't give me a transmission that I put in and still issue a warranty b/c what if I break something putting it in - it's not their fault).
So it's - they install it - it has 60,000 miles on it - with a new Honda OEM clutch (or a diff one if I prefer) - 6 month replacement/no questions asked warranty.
It's called a "no maintenance job" meaning that if it has a leak or anything and the trans fluid drains out they assume responsibility (unless I like bottomed out and took off half the transmission) and replace it for free - same day I bring it down there.
I'm trying to figure out how much a warranty is worth. It seems the going rate for a "like new" mint condition Y8 trans is 2-300 bucks. So it's just the warranty that's upping the price.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundpsych »</TD></TR><TR><TD CLASS="quote">yes there are many D series transmissions all over the place but he most likely wants an EXor"Y8" transmission because it has the closest gear ratio out of all the d series tr4ansmissions and 200-300 for a gaurenteed Y8 trans with only 60K is a good deal.</TD></TR></TABLE>
Yeah, I don't want a DX/HX/CX/GX/LX tranny - I want the shortest gear ratios, and I was even thinking of putting in a higher rear end but decided against it.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
I want the shortest gear ratios, and I was even thinking of putting in a higher rear end but decided against it.</TD></TR></TABLE>
rwd civic ftw!!
op- depending on the quality of the shop, id say that its worth at least a grand. shops dont go by honda-tech prices when it comes to parts- just bc you can get d series trannys cheap from people who did a swap, doesnt mean that the shops get them for cheap. and for it to have a full warranty is nice-3rd gear grind? take it in for a new one
rwd civic ftw!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 »</TD></TR><TR><TD CLASS="quote">where is the tech???
Search n00b</TD></TR></TABLE>
what the expletive are you telling me this for?
Personally, the warranty means nothing to me. I'd rather find another tranny.
If I had to go through the shop, I would not pay more than $450, you can get a complete swap for not much more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">
rwd civic ftw!! </TD></TR></TABLE>
Eh, rear end, final drive...same ****...
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Eh, rear end, final drive...same ****...</TD></TR></TABLE>
noooooooooo................... it isnt
syndacate can build a 552ci big block with nitrous, but cant install a SOHC tranny. AHAHHAHAHAHAHA, sorry, AHAHAHAHAH.
but really, a good used hydro sohc trans shouldnt be more than $125, then $300 for labor, so $425 is the max i would pay.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">syndacate can build a 552ci big block with nitrous, but cant install a SOHC tranny. AHAHHAHAHAHAHA, sorry, AHAHAHAHAH.
but really, a good used hydro sohc trans shouldnt be more than $125, then $300 for labor, so $425 is the max i would pay.</TD></TR></TABLE>
so he claims , he cant even rand r a civic exhaust
Average shop (not dealership) labor rates are abou $75 an hour. I would say that is a decent deal on a warranted and installed trans. However, it is easily done yourself if you get the car high enough in the air.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k powered ej1 »</TD></TR><TR><TD CLASS="quote">really syndicate there are no shops there huh? you paid someone to do your exhaust and now your trans </TD></TR></TABLE>
Not everyone has a welder. Or air tools.
Cut him some slack. We do the same for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
Cut him some slack. We do the same for you. </TD></TR></TABLE>
I do, cause i work on Hondas lol
Back on Topic: Why not just rebuild the tranny you have??
IMO rebuilding a d-series tranny isn't worth it. They're so cheap it's a waste of time.
I got my y8 tranny for $180 shipped with ~80k on it. Has been running great for 20k.
I DID however replace the pilot and the throwout bearing as a precaution. On the contrary I, like most people, aren't comfortable tearing apart transmissions.
Modified by ek forever guy at 8:02 PM 8/18/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">IMO rebuilding a d-series tranny isn't worth it. They're so cheap it's a waste of time.
I DID however replace the input shaft bearing and the throwout bearing as a precaution. On the contrary I, like most people, aren't comfortable tearing apart transmissions. </TD></TR></TABLE>
ISB is in the tranny lol if you replaced it then you tore it apart, and what i think actualy happened was you replaced the throwout bearing and pilot bearing
I stand corrected. I did replace the external/easy to reach bearings.
</TD></TR></TABLE>I stand corrected. I did replace the external/easy to reach bearings.
noooooooooo................... it isnt </TD></TR></TABLE>
I'm sorry, it's not the same, it serves the same purpose.
No, the labor isn't part of it - it's JUST THE TRANSMISSION, NO INSTALL. The point is that if the trans is shot the warranty says that THEY'LL replace it.
Secondly, it was a 509.
Thirdly, refer to the first paragraph once again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maynards_ek »</TD></TR><TR><TD CLASS="quote">Average shop (not dealership) labor rates are abou $75 an hour. I would say that is a decent deal on a warranted and installed trans. However, it is easily done yourself if you get the car high enough in the air. </TD></TR></TABLE>
I said trans + warranty, no labor - labor is being done here. I ask you read more carefully next time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat »</TD></TR><TR><TD CLASS="quote">yeah but syndicate, how much power/what are you doing to destroy a tranny for a d-series??</TD></TR></TABLE>
Stock, going rate for a trans here is 300 for a low mileage/mint cond. trans - I'm simply wondering how much you'd rate a 6 month full labor (THEY DO IT) replacement warranty is worth?
Coincidence, I have neither.
Back on Topic: Why not just rebuild the tranny you have??</TD></TR></TABLE>
I'm not sure it's just the ISB. the guy greased the **** outta it when I bought it so you couldn't hear it - so it went like 100 miles then started grinding like a *****. I don't know how much damage is done inside the transmission but don't feel like ripping it out and not having a replacement ready.
