help!!! i need picture of where the parking pole goes on the 4door eg ferio
Old Aug 15, 2007 | 07:27 PM
JUNKIE DUCKY's Avatar
Default help!!! i need picture of where the parking pole goes on the 4door eg ferio
i need to know where to cut the hole out for the parking pole i need a clean pic can anyone help
Old Aug 15, 2007 | 07:43 PM
no one anybody????
Old Aug 15, 2007 | 07:51 PM
Nickboxer7's Avatar
Default Re: (plockydox)
I thought I saw a picture of it on here. It takes a while to load and I don't know if it will help you at all, but I know I saw where it went on this.
https://honda-tech.com/zerothread/2070137
http://yhst-1408381693991.stor....html
Old Aug 15, 2007 | 07:56 PM
bumper great answer well ddnt find nothing on thread but dope thread thanx
Old Aug 15, 2007 | 07:58 PM
Nickboxer7's Avatar
It's not up close pics on that ferio thread but you can see the black part where it is. I think it's powered so it's just not sticking up in the pictures.
Old Aug 15, 2007 | 08:04 PM
BlackoutVTi's Avatar
Default Re: (Nickboxer7)
Are you looking where the pole is installed so you can put it in relatively the same position on the useful (opposite driver) side of your bumper, or are you intending to put it on the JDM side?
I'd hope it was the first reason. Other than suggesting you put it in a useful position, I took some time to search for you, and couldn't find you any pics of the actual cutout on the back of the bumper, sorry.
The only thing I could suggest now is to take a look at some installed pics, eyeball it, and install it on your passenger's side accordingly.
Old Aug 15, 2007 | 08:10 PM
Nickboxer7's Avatar
Default Re: (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">Are you looking where the pole is installed so you can put it in relatively the same position on the useful (opposite driver) side of your bumper, or are you intending to put it on the JDM side?
The only thing I could suggest now is to take a look at some installed pics, eyeball it, and install it on your passenger's side accordingly.</TD></TR></TABLE>
That's what I would do. Check out the pics on that ferio thread and put it on your passenger side about the same spot. It will be less useful if you put it on the JDM side, which is your drivers side.
Old Aug 16, 2007 | 08:53 AM
YEAH OF COURSE ITS GOING ON THE PASSENGER SIDE I JUST WANNA KNOW WHERE EXACTLY LIKE HOW FAR FROM THE EDGE AND THE HEADLIGH BUT ITS HARD GETTING A PIC THANX ANYWAYS
Old Aug 16, 2007 | 12:38 PM
NOFX's Avatar
H-T White Ops
If it's at all like the 6th gen one, mounting it will tell you exactly where to cut.
There should be mount points on the inside of the bumper. Once it's mounted (or just held up to the place where it should be mounted), trace where you'll need to cut.
That's where it will come out of the bumper.
Old Aug 16, 2007 | 12:42 PM
Padawan's Avatar
Darth ModerVader
Default Re: (NOFX)
Yes, I believe that's correct. Even on "USDM" bumpers, the mounting tabs and cut-out location should be present.
Old Aug 16, 2007 | 12:50 PM
COOL THANX SOUNDS GOOD
Zaraki
10
Aug 1, 2014 06:48 AM
oscarlx
Paint and Body
Mar 22, 2012 08:45 PM
AndyBaby
Jul 8, 2011 11:16 PM
EG694Si
Mar 10, 2008 08:14 PM
90 SiR Hatchie
Mar 8, 2005 11:53 AM
