MPFI swap repinning the plugs
Old Aug 15, 2007 | 07:07 PM
cticknor666's Avatar
Default MPFI swap repinning the plugs
Never messed with wiring or anything before. Just want to make sure i have the basic idea on how to do this down. From my understanding you look inside the plug at the wire you want to depin, then use something to go inside there and lift up the metal pin to release the wire right? Then just put in your new wire and press the metal back down?
Old Aug 15, 2007 | 08:10 PM
91DBSexyTime's Avatar
correct, good lucks with it, and try not to drink liquor when you do it, took 4 days to get done, plus had the wrong throttle body ;p.
Old Aug 15, 2007 | 08:18 PM
johndilt's Avatar
Default Re: MPFI swap repinning the plugs (cticknor666)
https://honda-tech.com/zerothread?id=1573760
Tippyman's thread should help you.
slowwhitehatch
Appearance Build Threads
Dec 24, 2008 05:54 PM
EJ ITO
Nov 19, 2007 05:35 AM
redman223
Jun 26, 2003 06:52 PM
xci_ed6
Jan 6, 2003 07:26 AM
