Convert to OBD1? or Swap oil pumps!?!?
Old Aug 15, 2007 | 05:20 PM
Japostol78's Avatar
Default Convert to OBD1? or Swap oil pumps!?!?
Whats up everyone....i need your opinion on this one...got a 01 Integ LS...OBD2 and so forth..swapped in a 98 jdm b20 in it...everything plugs in..EXCEPT the oil pump sensor...since the b20 doesnt have one on its oil pump....
Question is....
Should I go through the trouble of swapping oil pumps from my LS motor to the b20 OR just get the obd1 Ecu and a conversion harness??
Old Aug 15, 2007 | 05:29 PM
j87w's Avatar
Default Re: Convert to OBD1? or Swap oil pumps!?!? (Japostol78)
I have done a few swaps like this. I wouldnt even bother switching the oil pump. But on all of them I informed the customer and I converted the car to OBD1. Its way easy on a DC chassis, just get a OBD2B to OBD1 ECU Jumper Harness and then an OBD1 ECU for your setup. You could use a P75 ECU or have a custom one from phearable or such. I heard and I dont know if this is true but you may be able to just complete the circuit with the oil pump switch. I believe its just a 2 wire switch (IIRC) and I think its just an on or off. You may do some more research in that. Hope that helps a bit.
Good luck
Old Aug 16, 2007 | 09:57 PM
Japostol78's Avatar
Default Re: Convert to OBD1? or Swap oil pumps!?!? (j87w)
thanks...i think i'll just go n get a p75 and a conversion harness...you know..i did the obd2-obd1 conversion when i had my LS motor in...everything worked fine but the tach didnt work at all...thats why i ended up sellin the harness i had and the p75 ecu...any knowledge on why it didnt work??
Old Aug 16, 2007 | 10:24 PM
j87w's Avatar
It sounds like its related to another problem. I have converted alot of cars from OBD2B, OBD2A, OBD0 to OBD1 and I have never had one problem. The OBD2B and OBD2A are just simple conversions the OBD0 one is a little bit more involved. But no problems with the tach or vtec or anything like that when converted.
Old Aug 17, 2007 | 03:08 PM
Japostol78's Avatar
i'm thinkin it could be the harness i got....well hopefully this time around i dont have any problems...i'm about to pick up a p75 ecu and lookin around for a harness...thanks for the help...
Old Aug 22, 2007 | 09:02 PM
Japostol78's Avatar
hey whats up...again thanks for the info on the obd1 conversion...i got a p75 and a obd2-obd1 conversion harness....my CEL light is now off thank goodness...2 things though...first...the tach isnt working...n second..the car idles funny at startup...sounds like its gonna die out..but when its warmed up..its cool...any info you can give me ??
Old Aug 23, 2007 | 08:01 PM
Mfoehrkolb's Avatar
you mmight be to fabricate a end peice to plug thee harness with. the part for the pil pump isnt that seriours. if you have any minor electronic capabilities you should be able to "re route" it to not throw a code.
Turbo-GSR1287
Apr 12, 2008 08:20 AM
xQB21x
Jan 24, 2007 04:39 AM
connvict
Sep 1, 2004 08:10 AM
Samsonite
Nov 2, 2002 07:34 AM
