Tachometer
Old Aug 15, 2007 | 12:42 PM
r3dp1n0y's Avatar
Default Tachometer
My new EG has no RPM reading and my friend gave me a 5" tachometer. Now the only problem I have is I dont know how to install it. The wires on the Tach is red, black, green and yellow. Thank you for your help.
Old Aug 15, 2007 | 12:48 PM
spoolin69's Avatar
Default Re: Tachometer (r3dp1n0y)
what brand tach...why dont you just get a new cluster with rpm...
all the wires should be is power ground rpm signal and i think but cant remember cause its been so long since iv seen one of those ignition switch
Old Aug 15, 2007 | 12:52 PM
bmoua's Avatar
Default Re: Tachometer (spoolin69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin69 &raquo;</TD></TR><TR><TD CLASS="quote">what brand tach...why dont you just get a new cluster with rpm...
all the wires should be is power ground rpm signal and i think but cant remember cause its been so long since iv seen one of those ignition switch</TD></TR></TABLE>
but he got the tach for free so might as well. The only thing i'd be worried about is drawing attention from theives.
Old Aug 15, 2007 | 01:04 PM
PinoyxEJ6's Avatar
run the black and red wire to the battery, green wire to the blue wire towards the blue dizzy wire.. and than the white wire to one of the dimmer light wires.. HOY PUTANG INA ****!
Old Aug 15, 2007 | 01:23 PM
spoolin69's Avatar
Default Re: Tachometer (PinoyxEJ6)
he dont have a white wire...i think the yellow runs to dimmer...now that you said the white wire i remember now when i ran the white wire on the autometer tach to the dimmer too...
ivan1985
11
Dec 19, 2006 03:31 AM
99sibluehatchwitb16
Jan 26, 2006 12:47 AM
Jeef
May 5, 2004 07:18 AM
solohatch
Dec 28, 2002 02:00 AM
preluder
Dec 22, 2002 09:51 PM
