cracked tranny case
AS A TEMPORARY FIX.
First check exactly where its leaking from, let EVERY SINGLE OUNCE of fluid drain out of it. Make sure its bone dry. Take some brake cleaner and clean the **** out of the area where the crack is, then dry it off. Now get the 4 minute JBWELD, seal that bitch up and leave for as long as possible. Pour back in tranny fluid, check for leaks. This held up for me for a couple of months when i was broke. Best of luck.
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic »</TD></TR><TR><TD CLASS="quote">keep adding fluid and wait for the wee little crack to grow. you can have it welded....you just have to find somebody that can weld aluminum.</TD></TR></TABLE>
weld cast aluminum? I dunno how great that weld would be....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oreozzz »</TD></TR><TR><TD CLASS="quote">AS A TEMPORARY FIX.
First check exactly where its leaking from, let EVERY SINGLE OUNCE of fluid drain out of it. Make sure its bone dry. Take some brake cleaner and clean the **** out of the area where the crack is, then dry it off. Now get the 4 minute JBWELD, seal that bitch up and leave for as long as possible. Pour back in tranny fluid, check for leaks. This held up for me for a couple of months when i was broke. Best of luck. </TD></TR></TABLE>
This might be a permanent fix, though.
You could also use some silicone sealer. This stays pliable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
it is done every day. i have welded cases on dirt bikes before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">weld cast aluminum? I dunno how great that weld would be....</TD></TR></TABLE>
Any decent welder can do it, I've done it. The weld isnt going to be load bearing. it will be to keep fluid from draining out.
I'd go with the JB weld IMHO.
or just buy a trans and use the case
jdmstyleEJ6
12
Apr 2, 2010 08:07 PM
Elwuudz
Jan 15, 2006 07:54 PM
