accord 97 suspension
Hi, I own a 97 accord, and lately front suspension is making noise. In normal driving, I can go over a speed bumper without any sound, but in rough (non perfectly flat) streets, sometimes it makes a fast repeated, knocking sound. Went to the honda stealership, and the owner himself eye checked it, said that everything seems to be ok, so the reason could be the "bump stop". He is going to charge me 200$ for the job, when the parts only represent 60$. I really want to know if that is the reason for sure, or if anyone has experienced something similar and solved it doing something different. (I've seen 98 civics doing the same sound).
Thanks
Abilio Marques
Thanks
Abilio Marques
The bump stop is a little tan/white piece at the top of the suspension assembly that stops the thing from bottoming out, maybe yours is loose/damaged?
Labor wise that's probably correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">The bump stop is a little tan/white piece at the top of the suspension assembly that stops the thing from bottoming out, maybe yours is loose/damaged?
Labor wise that's probably correct. </TD></TR></TABLE>
really?
I find places that do springs for 100-150.
really?
Brad1
Apr 5, 2023 04:35 PM
colt1210
Feb 3, 2014 12:03 PM
wolfievtec
May 12, 2007 07:53 AM
97, 9902, accord, bump, front, honda, hondatech, knocking, noise, sound, stop, stops, suspencion, suspension, suspensiones
