EG rear hatch
Old Aug 15, 2007 | 10:06 AM
DCivic00's Avatar
Default EG rear hatch
Does anyone know where to get the plastic plugs to put into the rear hatch when you don't have the struts anymore? I've been trying to find them online, but don't know the part number or if it's something you can get from Honda.
Old Aug 15, 2007 | 10:11 AM
crazyguy's Avatar
Default Re: EG rear hatch (DCivic00)
u can get it only from honda.
it is about $5 a piece
it is 14 shown in the pic
part number 74671-SH3-010
Old Aug 15, 2007 | 10:17 AM
Relic1's Avatar
or are you refering to the rear struts that hold up the glass?
Old Aug 15, 2007 | 10:21 AM
DCivic00's Avatar
After finding another picture, I may have realized that it might be one of the pieces that holds the strut in place. Either #21, 22 and 23. Is this correct?
crazyguy's Avatar
Default Re: (Relic1)
oh that too
here is the part number
Old Aug 15, 2007 | 10:22 AM
DCivic00's Avatar
Yea my bad, the one's for the glass.
Old Aug 15, 2007 | 10:23 AM
DCivic00's Avatar
Is it the one that's showing as part #21?
Old Aug 15, 2007 | 10:28 AM
crazyguy's Avatar
Default Re: (DCivic00)
ok now i know what u are saying and it will not work.u will need the rear strusts to hold the lower glass nut and seal in its place.cause there is a bolt on the rear strat (lower side that mounts on the glass) that goes on the number 21 which is a screw.cause i have just replaced the struts and all the rubber seals and screws.costs me about $100
Old Aug 15, 2007 | 10:31 AM
DCivic00's Avatar
Default Re: (crazyguy)
Well what I was planning on doing is taking out the rear strut. I've seen on other peoples hatches that don't have the glass strut, but only have a piece of plastic that fits in the holes on both sides. That's what I'm looking for.
Old Aug 15, 2007 | 10:52 AM
crazyguy's Avatar
oh.in that case i have no idea,but a piece of advise.if u mess around with that 2 lower seals on the rear window.it will leak.once u park your car outside and it rains.your cargo area will be soaked.cause those 2 metal screws hold 2 weather seals.just a friendly reminder cause my hatch was leaking thats why i replaced all the seals.include the rear wiper seals.
Old Aug 15, 2007 | 11:29 AM
Relic1's Avatar
the only time I've seen no rear struts on the rear window like that, they put in two shorter 8mm bolts and a couple washers to hold the normal buttons in place.
just in case you still want them.
#21 - 90101-SR3-000 - nut, opener stay piviot (lower)(8mm)
#22 - 90105-SR3-000 - seal, tailgate opener stay & Wiper motor
#23 - 90106-SR3-000 - spacer, tailgate opener stay
Old Aug 15, 2007 | 11:51 AM
DCivic00's Avatar
Ok I think I understand now. Thanks for the help.
Old Aug 15, 2007 | 01:31 PM
darkclark's Avatar
if you just want some plastic plugs for the hole i bet they have some at your local hardware store just measure the size of the hole the ask for plastic end caps in that size
Old Aug 15, 2007 | 01:47 PM
chuisek9's Avatar
Default Re: EG rear hatch (darkclark)
when i did one i got the plug from the engine bay!!
bambbrose
Feb 16, 2010 10:04 PM
e-eg6
Sep 30, 2008 10:34 AM
al3e
23
Jun 8, 2004 09:58 AM
F120man
Dec 19, 2002 05:20 AM
